Looking for TextO'LE
First post, by filipetolhuizen
Back when I had a SB32 PnP I could get this program from a friend's SB16 CD and it was damn fun. Now I cannot find it anywhere over the net anymore and every SB CD I found does not have it. Is there anywhere I can get it?
Reply 1 of 6, by leileilol
Surely it's on that Ultimate Sound Blaster disc found around here? I haven't looked. I don't think it had an apostrophe as what the about box would have told you... "Creative Text Olay!!!"
I know I used it before. I guess you're fond of the Willowpond / Lernout & Hauspie speech engine that it used, and the demonstrating of the 'singing' voices text file?
long live PCem
Reply 2 of 6, by filipetolhuizen
Yes indeed. I remember telling my father the computer could speak any text file using this program and he didn't believe me. When I loaded it up his jaws went to the ground. So, which CD is that? On which section is it found here? I tried getting lots of SB install CDs from here but most links are dead.
Reply 3 of 6, by leileilol
I know it's on my AWE64 cd. I think it was installed with the driver suite along with the multimedia decks and wave studio. To find out i'd have to reinstall these things 😀
EDIT: Just checked. Ain't there!!! Just SoundOLE which is "Creative Sound Recorder". I know I have TextOLE somewhere.
Mindmaker Prody Parrot also used the same speech engine and I think it had something like Text OLE but I know Prody isn't what you're looking for. I'd suspect TextOLE might be on TheMAN's sb16awe cd image.
EDIT 2: TheMAN's cd has it. tasstupg/ folder contains a setup that installs Text OLE, but I can't get it to install in Windows 98SE. Says some crap about a bad install script D:!!!! (way to go InstallShit eld)
long live PCem
Reply 4 of 6, by TheMAN
Did you read the readme file? 🙄
*** IMPORTANT NOTE *** […]
You MUST already have installed Creative TextAssist before you
run this Upgrade package. If not, please install the original
TextAssist first (from the original disks included in your Creative
audio card package) before running this upgrade.
The base install is in the TAMO folder... again, you'd know this if you looked in the index
Reply 5 of 6, by leileilol
I actually did install TAMO first.
long live PCem
Reply 6 of 6, by TheMAN
if you think the installation files are corrupt, try the original zip file that's also on that CD
the upgrade worked fine for me when I last tried it years ago, so there might be some issue with your system
