First post, by computergeek92
Hello everyone. I'm in the process of upgrading my retro file server to a dual cpu system since my current 800MHz Athlon PC using the Gateway Jabil Kadoka (Slot A) Motherboard and 768MB of RAM cannot play DVDs smoothly. All I wanted this PC to do is run Windows Server 2003, play DVD's good, not skip when playing music files, and store my files, but even burning DVD discs takes up most of the cpu power. I've tried using an Nvidia Geforce 256 AGP card with 32MB VRAM and the DELL dvd decoder card from a system I scrapped, then a single Geforce2 MX400 with 64MB of VRAM. Both configurations produced green hues and unsmooth playback. This probably has to do partially with the mobo's crippled AGP 2x bus on it's AMD 750 Irongate chipset that ony runs at 1X speed. I even tried a PCI ATI Rage 128 with 16MB VRAM and DVD's played without any color problems but still skipped mostly. I found an awesome looking motherboard on Ebay called the Intel L440GX+ which supports dual Slot 1 (100MHz fsb) Pentium III's up to 850-900MHz and supports up to 2GB of RAM. I currently use VLC media player. Is this media program dual processing capable so that DVD playback runs at a theoretical 1400MHz combined speed? Or are there freeware SMP media players I can use instead?
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
