First post, by snorg
Virtual box often comes in handy for emulating an older OS on newer systems, however what do you do when you want to emulate a complete environment on an older system? Say, 386/486 or Pentium !/II?
I figure you won't be able to easily emulate a full graphical OS on a 386/486 system since they just aren't as powerfui but a P200 level system would probably be beefy enough to emulate several GUI type OSs even with the performance hit due to emulation, you would just have to be willing to tolerate the hit.
I guess why I'm asking, is I'd like to have OS/2 in a virtual machine on a Win 95/98 box so I have the option to go back and forth without having to dual boot. If that's not possible, then I guess dual boot is an option.
Reply 1 of 5, by snorg
Or if it is not possible to do the above, then maybe a way to run Win 95 inside OS/2 Warp, although I doubt this is possible. I think there was something called Soft 95 but I don't think this was ever available for OS/2. Something tells me the best/most realistic option is going to be "just dual boot it".
Thanks in advance.
Reply 2 of 5, by DosFreak
Connectix Virtual PC works on OS/2 (Not Microsoft Virtual PC)
I believe there is also a OS/2 port of VirtualBox.
http://en.wikipedia.org/wiki/Windows_Virtual_PC
http://wse2010.warpevents.eu/uploads/tx_wseev … tualization.pdf
Bochs 2.3.7 works on 95 and NT4
Bochs 2.6.6 works on 98+
Qemu 6.0 works on Windows 95
Qemu 7.0 (with acceleration) works on 98-ME-NT4 if you hexedit the binaries
Qemu 14.0 works on 98-ME-NT4 if you hexedit the binaries
Virtual PC 5.1 works on 98-ME
Virtual PC 5.2 works on NT4
Vmware Workstation 4.5.3 works on 98-ME-NT4
DosBox works on OS/2,95/NT4-2012R2 😀
From my experience you'd be better off using OS/2 or NT4 as the host if you plan on using virtual machines.
Vmware Workstation would usually exceed Virtual PC performance wise. Never used VirtualBox on OS/2 nor on hardware that old so hard to say how that would perform.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 5, by pewpewpew
And KVM. The cheapest odd-brand ones are to be avoided, but I've been completely happy with my inexpensive IOGear switch for about a decade now. It's five star stuff.
Reply 4 of 5, by leileilol
VirtualPC is the fastest solution I know of.
VirtualBox is very slow and relies on virtualization extensions on modern CPUs for it to work well.
For Linux however, dosemu can be very fast.
Reply 5 of 5, by Kreshna Aryaguna Nurzaman
I still have yet to find Virtual Machine solutions that enable us to use USB joystick on the host machine, which is then translated to gameport joystick on the guest machine. 🙁
Kreshna Aryaguna Nurzaman.
