First post, by Chaniyth
The Gigabyte GA-486VS I got has had the barrel type battery removed by the seller before I purchased it, there is zero damage done to the board, so I am looking to adding a coin-style battery to it instead. So I have several questions: Can this be done, is there any specifics I should know before doing this, etc?
The board, according to the manual, has a connect on the board (J1) for an "external battery" source too but I dunno what that would be. Here's an excerpt from the manual...
There is a re-chargeable battery on board, also there is an external battery
connector on board. The user can close jumper JP16 pin 1-2 to use re-
chargeable battery, or add an external battery to mainboard by connect it to J1.
So, if I can use the external battery source that will save me time from having to solder a coin-style holder on the board. However I have no idea what this "external battery" would even look like, so hopefully someone here can shed some light on what it is and what it looks like. Thanks in advance for any info or advice.
All the world will be your enemy, Prince with a Thousand Enemies, and when they catch you, they will kill you... but first they must catch you. 😁
Reply 1 of 19, by Chaniyth
Ok, so I think I have some idea after doing some searching of what it is and what it looks like so I took my PCChips M919 motherboard [such a total POS motherboard] and i'd never be using it again so I desoldered off the coin-style battery holder.
Now I just need to get a wire of some sorts, could I hack this wire to work with the 2-pronge coin-style CMOS battery holder?
Thanks. 😎
Reply 2 of 19, by badmojo
I've used a PC speaker wire with success. From memory though those coin batteries are only 3V, and some boards require more - 3.6 maybe? Give it a try, but if your board can't remember what time it is, then suspect the battery.
Reply 3 of 19, by carlostex
You can for sure make a CR2032 mod, i actually modded all my 386 boards and it works ok. But keep in mind that in those days barrel type batteries were rechargeable, so when the Computer is on current will go to the battery. You might want to use a schottky diode ro make the current flow unidirectional so that it prevents a CR2032 from being recharged.
Doing so, should be fine and will avoid possible nasty consequences. And also keep in mind what badmojo said, about 3.6V vs only 3V.
Reply 4 of 19, by konc
Just connect a coin battery to J1, set the jumper to use that one and you should be fine. There is this voltage difference mentioned (3,6 - 3 volts) but I've never encountered a single board not holding its data with a 3V coin battery. I've even used 2 AA's taped together in such cases 😀
No need to mess with recheargable batteries since the board has a connector for an external one. Not only it'll save you the trouble of soldering on the board, but also keep in mind that even if you do decide to replace the recheargable battery on the original location, the new one has to be of the same type. For example, if the original was a Ni cad barrel, it't not advisable to replace it with a modern Li-ion recheargable coin (they charge differently).
Reply 5 of 19, by gerwin
My 486 mainboard insists on 3,6V. UMC chipset, VLB slots.
Reply 6 of 19, by konc
Well... you got me here 😀 Still, rule of thumb is that it that most probably it'll be OK, but I'm intrigued by this exception
Reply 7 of 19, by Matth79
I'd be inclined to wire a 3 cell AAA holder of NiCd or NiMH to the connections of the barrel battery - not sure if the trickle intended for a smaller pack would keep them topped up though.
Reply 8 of 19, by jesolo
Some older motherboards had an external battery connector. If it doesn't, then you can actually still obtain replacement NiCd batteries which you can just solder back onto the motherboard where the original battery was.
I've recently had to remove my 386 motherboard's NiCd 3.6V battery as it was starting to show signs that it was leaking (despite it still managing to keep the time - after all these years).
I then plugged in a 3x AA (1.5V x 3 = 4.5V) battery holder but, it wasn't keeping the time.
I then had to up the voltage by adding another AA cell (1.5V x 4 = 6V) and sure enough, now it's keeping it's time.
However, it is true that, with some newer 486 motherboards (that still utilised the NiCd batteries), 3V might be sufficient.
Below is a link to a website I found that provides all the information you need.
http://pc-restorer.com/replacing-cmos-batteries-in-old-pcs/
Reply 9 of 19, by Chaniyth
I was looking through my closet and found the perfect female-to-female jumper wire, I connected the black to the Battery Cathode (-) and red to the Battery Anode (+) on the coin-style holder and J1 jumper on the motherboard and it seems to be working great. 😁
Reply 11 of 19, by tayyare
Both of these below are the ones I used before, without a single problem in 386/486 PCs. I asked before the same question, and suggestions are for 4xAA more than 3xAA. And yes, I also used old speaker connectors to mod them.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 12 of 19, by gerwin
For a while I used that one displayed at the bottom. But in one battery compartment I put an M6 Hex Bolt, as to short it. Giving 4,5 instead of 6 V.
I would have preferred the compact 3V coin cell setup, even added the holder. but it won't work...
Also looked around for these 3,6 V coin cells LIR2032, but these are either a little expensive or suspiciously cheap...
Reply 13 of 19, by PeterLI
Last year I ruined a MOBO with a self built solution I believe. I either put in a 4.5 or 9 volt battery to the external hookup to replace this rechargeable external battery that had been in there. It did not recharge. But that is different from a cell battery setup obviously.
Reply 14 of 19, by King_Corduroy
I have successfully used a coin battery in place of an external Lithium rechargeable battery on my 386 system! All I did was desolder a holder from a dead mobo and then I wired that to a clipped fan wires and plug and plugged it right in. As long as you match the polarity you should be good. 😁
Check me out at Transcendental Airwaves on Youtube! Also wtf, why are whoppers so good?!
Reply 16 of 19, by pewpewpew
carlostex, thanks for the heads-up.
I'm using the CR2032 mod on my ASUS ISA-486. Since there's no manual for that early board, I don't actually know if the original external was/wasn't rechargeable. Hadn't thought about it till now. And of course putting a regular cell in a rechargeable's position is just asking for fire down the road. So thanks for that. I've just dragged the 486 over to the bench for attention next time the iron is warm.
Reply 17 of 19, by konc
Those are Li-ion rechargeables, although in practice it won't make any difference (except from shortening the battery's life), in theory it's not right to replace a Ni-cad etc with a different type, as I said earlier they charge differently. Again, this is just for the discussion and practically safe to try...
Reply 18 of 19, by carlostex
No worries. The diode will never hurt since if you orient it correctly it will only allow current from the coin cell to the motherboard and not the way around. A coin cell being recharged could result in disastrous consequences. So i will always recommend this when doing a CR2032 mod.
