Kodai wrote:I've never seen or heard tell of fire issues from using lighter fluid on the bands and rigs as ending up flammable (it normally a small drop or two that is worked into the surface of the rubber), but if seen and been forced to clead the aftermath on the playfield. It a total nightmare and it does permanent damage to the play field surface that can not be repaired.
Go dig through Pinside and you'll definitely find stories of people's games catching fire or at the very least, smoking. Substances like contact cleaner and WD-40 are considered absolute bad news as far as dealing with playfield components. x_x;
Kodai wrote:As far as tempered glass goes, I've (more often than not) seen it break a long, sharp shards. I thank some of you are thinking of safety glass which is also tempered but with extra steps that may include stacked sheets with glue and clear mylar. I have seen tempered glass crumble into smaller, safer bits but not very often.
I know the differences. What you're talking about in terms of glass breaking into long, sharp shards, is NOT tempered glass, it's plate glass, often used as a substitute in pinball machines due to being cheaper and incapable of exploding. The trouble is it's nowhere near as strong as tempered glass across its surface and breaks into larger, ultra-sharp fragments. Plus, if a pinball strikes plate glass hard enough, it can crack or break it.
It is physically impossible for temepered glass to break into large shards. The instant the integrity of tempered glass is compromised, it explodes into many thousands of tiny, dull fragments, due to the extreme internal pressure it's under. Here's an article detailing the stuff which you may wish to read through: http://en.wikipedia.org/wiki/Toughened_glass
Another good read to learn more about the properties of tempered glass: http://en.wikipedia.org/wiki/Prince_Rupert%27s_Drop
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
