This might be a long list 🤣!
Anyway, here goes!
*CPU*
386DX-33
Intel 486DX4-100 (wt and wb)
Pentium Overdrive 83MHz
AMD 5x86-133
Cyrix 5x86-133
Pentium-60
Pentium-200 non-MMX
PentiumMMX Overdrive-200MHz
Pentium-233MMX
Pentium Pro-200 (256KB, 512KB and 1M versions, @233MHz would be a bonus)
Cyrix MII 2.2v that can run 300MHz
Klamath 300MHz
Celeron 300MHz Slot 1 without cache (only have a single 266 cacheless one and a couple 300A's)
K6-III 2.2v that can run 400MHz
Celeron s370 400MHz
Pentium II 400MHz with unlocked multipliers
K6-2 550MHz
K6-2+ that can run 550MHz at 2.0v
K6-III+ that can run 550MHz at 2.0v
Celeron 533 s370 Mendocino
Katmai 600MHz
Celeron s370 766 (if only because of its crappy FSB ^^)
Celeron s370 800MHz
Coppermine 800MHz EB
VIA C3 800MHz pre-Nehemiah
Duron 800MHz
Coppermine 1GHz EB
VIA C3 1GHz Nehemiah
Thunderbird sA 1GHz
Celeron 1GHz/Coppermine 1GHz 100FSB (don't have any of these Coppermines though)
Tualatin 1200
Tualeron 1200
VIA C3 1.2GHz Nehemiah
Tualatin-S 1400
Tualeron 1400
Tualeron 1400 ES (hope I didn't fry this one)
Thunderbird 1400
Willamette s423 2.0GHz
Palomino 2000+
Thoroughbred 2000+ (Mobile chip, came from my mother's laptop which had died due to peeing cat of hers...lucky me ^^)
Barton 2400+ (mobile chip)
Barton 3200+ (the 400FSB variant)
Northwood 3.2GHz
Athlon 3200+ s754 2.2GHz
Athlon 3500+ s939 Venice 2.2GHz
Phenom II 3.2GHz x4 BE
*Motherboards*
Socket 3 board (several, but at least 1 VLB and 1 PCI each, with coincel and PS/2 etc)
Socket 4 board
DEC AXPpci33 (166MHz in 1993, one day AXP, I'll be able to kick you back to life muahahaha!!)
Socket 7 board ATX SiS (preferably one frem BCM)
Socket 7 board ATX 430TX (ASUS TX97-XE)
Super 7 board ATX SiS 530
Super 7 board ATX Ali (I really like the GA-5AX ^^)
Socket 8 ATX (support for 1 CPU is good enough)
Slot 1 440LX (often have lower FSB settings than 440BX)
Slot 1 440BX (one that will run Coppermine)
Slot 1 820 (because of the RAMBUS ^^)
Slot 1 with newest VIA chipset I can get)
s370 440LX (was my 2nd computer I ever build using the above mentioned Celly 400)
s370 440BX
s370 815 for Coppermine
s370 815 for Coppermine and with ISA slot (bridge chipped, came from a Fujitsu Siemens, also nostalgia)
s370 815 for Tualatin (I really like the GA-6OXT ^^)
s370 VIA chipset with support for Tualatin and an ISA slot
s423 board (any that will work)
s478 Intel 865 chipset
sA VIA KT133A (ASUS A7V133, this one is a challenge to get running nicely)
sA VIA KT333 (I really like the A7V333, too bad I fried my first one)
sA VIA KT600 (nostalgia, ran my Barton 3200+)
s754 with VIA chipset and southbridge that will work with SATA2 devices
s939 with VIA chipset and southbridge that will work with SATA2 devices
I'm sure I forgot a couple but meh, lets go on ^^
*Grahpics Cards*
Diamond Speedstar 64 2MB ISA
S3 Virge 4MB (PCI)
Rendition Verité 2100 (Diamond Stealth 2 S220)
Voodoo 2 with 12MB
Voodoo 3 2000 PCI and Voodoo 3 3000 AGP
Voodoo 4 AGP
Vanta 16MB AGP (because of its alright performance for how little power it uses, doesn't even have a heatsink ^^)
TNT2 M64 16MB PCI
TNT2 proper 32MB (Viper S770 non-ultra because it is passive)
Geforce2 MX 440 AGP 64MB (ASUS V7100PRO/64M because I really like the looks of this card for some reason)
Geforce 3 ti200
Geforce FX 5900u
Radeon 9600 (both Pro and XT)
Geforce 6800 AGP (preferably with at least 256MB)
Geforce 7600GS AGP with 256MB and large passive cooler with 8cm case fan rigged to it, got 2 of them when new
HD4670 1GB GDDR5 AGP
HD5670 1GB
HD6670 1GB
HD6850 1GB
*Sound cards*
Aztech Galaxy...something. I never actually got to use it, but this huge card just looks so damn nice 😁)
Sound Blaster AWE32 (memory sockets 😁)
Sound Blaster AWE64 or the Gold variant
Sound Blaster Live! (provided it's not one of those OEM ones which brings driver hell)
Some PCI sound card with Yahama chip I think, it's in one of my rigs and I dunno which one 😵
*Other stuff*
2.88MB floppy drive
LS-120 Internal drive
ZIP 250 USB (because of it's fantastic looks! I still like to pull it out from time to time and use it for whatever reason 🤣)
FSP-built PSUs (especially the ones with good power for the 5v line)
