First post, by Splinter
I've acquired a nice home theatre speaker system but I'm not sure how to connect it correctly to the PC to get 5.1 surround.
For the moment I've connected a Y splitter to the green audio out on the PC and the RCAs to the DVD input on the sub woofer.
I'm not actually sure if the three inputs on the sub have different characteristics or not anyway.
I'd read somewhere that the three generic sound ports..line in, audio out and mic (blue,green and pink) also serve as sub and speaker options.
I'd also be happy to buy a dedicated 5.1 PCI sound card if that helps because the VIA integrated sound is just 2 channel I believe.
Any ideas?
Cheers
MPslv0D.jpg?1
http://www.compufixshop.com
Main rig Ryzen 2600X Strix RX580 32GB RAM
Secondary rig FX8350 GTX960 16GB RAM
Reply 1 of 6, by gdjacobs
It doesn't look like that amplifier has discrete 5.1 inputs. It's either doing matrix decoding or it has SPDIF inputs (maybe below the stereo game inputs) for AC3 and/or DTS. Of course, this could be a white van special which handles neither of those things.
What's the model number of the amp?
Reply 2 of 6, by Splinter
It's a Durabrand home theater system ht3915.
Reply 4 of 6, by gdjacobs
Yeah, at best it's doing matrix decoding, but Lennoxx aka Durabrand doesn't appear to license anything from Dolby (or anyone else). Cheap and nasty. Don't expect much.
Reply 5 of 6, by Splinter
Cheap yes, but not nasty actually and produces a decent sound which is a darned sight better than the TV does.
I dug out a nice Audigy SE which works beautifully with Windows 10 so let's see what it can do.
Reply 6 of 6, by gdjacobs
I guess I'm being persnickety, but "better than the TV" is a pretty low bar. The nasty is likely waiting for you under the skin. If you open it up, I expect you'll find an undersized transformer and a few single chip amplifier solutions mounted to completely insufficient heat sinking. Everything built to a price.
