First post, by DracoNihil
- Oldbie
I don't know if this is the right forum to ask this question because it happens in emulation or on a real MS-DOS system. You can even find videos of this happening on real hardware too.
But, to the point: Why does the music tempo slow down and speed up variably when you're using either OPL2 or OPL3 for MIDI music in Descent? It slows down even worse in OPL3 I might add as well... This is the only game I know of that has this strange problem.
If you use MPU-401 for music the tempo stays consistent throughout the songs, but the OPL versions of some of the tracks sound better and are more unique sounding compared to the GM versions.
― Κυνικός Δράκων
