First post, by Jorpho
- l33t++
I tripped over the keyboard cable of my main PC just now, abruptly causing the PC to reboot. (I will never recall what I had written down in Notepad. 😢 ) This isn't the first time I can recall this happening, but I can't seem to get the keyboard to respond anymore. Upon plugging it in, the three lights (Num Lock/Caps Lock/Scroll Lock) turn on for a second and then instantly switch off again, after which the keyboard is unresponsive. This occurs with more than one PS/2 keyboard, both of which function normally on a different PC.
The PC is working perfectly fine. The only thing I can think of to do is wait, and hope that some kind of resettable fuse got tripped in the motherboard.
Is this a thing that has been known to happen?
