Wow, thanks for all of the responses! 😀
SPBHM wrote:temperature monitors in "GPUs" became common around 2004+
for the voodoo the old method of touching the heatsink is what you have,
That explains the reason why there is no direct way of measuring the temperature of the Voodoo3's GPU "directly".
The reason why I want to get the GPU's temperature directly is, besides just "it's good to know", is that I want to overclock the card.
SPBHM wrote:Voodoos normally ran hot with the stock cooling, but if you add a little extra, like a fan on the passive cards you should be good.
This I have already addressed. Behold, my Voodoo3 with a 40x40x10mm silent Noctua fan (NF-A4x10):
https://i.imgur.com/FaUBeNY.jpg
I learned of such an idea from PhilsComputerLab (his video on the matter of cooling a Voodoo3: https://www.youtube.com/watch?v=aszC13E-B-k). Great guy!
I also plan to put heatsinks like this:
https://i.imgur.com/nMtd7rC.jpg
on the VRAM modules on the card to keep the memory cool while overclocking.
chinny22 wrote:But your motherboard has a header just near the CPU ladled "JTPWR"
But you can get a 2 pin Thermal sensor similar to ones that come fan controllers like the below and use that to monitor the temperature.
http://www.ebay.co.uk/itm/Maplin-2-Pin- ... Sw7FRWWK2O
That's is indeed what my motherboard has, and now I have an excuse to use it. 😀
"One" more question then, chinny22: How would you suggest to attach that "JTPWR" sensor to the heatsink on my Voodoo3? Tape? Thermal tape? Something-with-thermal-in-its-name-that-is-sticky? Or maybe just zip-tie it somehow to the heatsink? I mean, the sensor should be in physical contact with the thing it's sensing the temperature of, right? Thanks in advance!
