First post, by MetalMilitia
Hey guys. I've been searching for old "bubble style" case badges and haven't had any luck. Does anyone on here sell them? Thanks!
Reply 1 of 2, by x0zm_
They're quite easy to make yourself if you aren't picky about it being authentic or using higher quality materials.
If you want to do it on the cheap, grab some glossy inkjet/laser printer compatible adhesive paper and some 25mm / 1 inch square epoxy domes. Print out what you want, apply dome on top, cut it out and put it on the case. Total cost can easily be under $5 for a few of them.
Reply 2 of 2, by badmojo
This is what I've done:
Case badges
