First post, by Peter Swinkels
Trying to better understand MS-DOS executable headers and what relocation items are I looked at the DOSBox source code and found this in the .\dosbox\src\dos\dos_execute.cpp file:
		pos=head.reloctable;DOS_SeekFile(fhandle,&pos,0);
for (i=0;i<head.relocations;i++) {
readsize=4;DOS_ReadFile(fhandle,(Bit8u *)&relocpt,&readsize);
relocpt=host_readd((HostPt)&relocpt); //Endianize
PhysPt address=PhysMake(RealSeg(relocpt)+loadseg,RealOff(relocpt));
mem_writew(address,mem_readw(address)+relocate);
As far as I understand C++ it's iterating through each relocation item in the header and calling a function called "PhysMake". What exactly is going on in the above code?
Reply 1 of 3, by jmarsh
When the executable is built it doesn't know what its base address will be when it gets run. So a lot of memory references in the code are placeholder values ("relocations") that have to be corrected when DOS loads the program.
Reply 2 of 3, by Peter Swinkels
jmarsh wrote on 2020-04-20, 12:31:
Can you be more specific? Are the relocation items in the header the addresses of these place holders? How are these placeholder values modified?
Reply 3 of 3, by Peter Swinkels
Here is some vb.net code I wrote in attempt to interpret an executable's (meant for MS-DOS) relocation table:
Option Compare Binary
Option Explicit On
Option Infer Off
Option Strict On
Imports System
Imports System.IO
Public Module Module1
'This enumeration list the MS-DOS executable header's items.
Public Enum MSDOSHeaderE As Integer
Signature = &H0% 'The MS-DOS executable's signature.
ImageSizeModulo = &H2% 'The executable's image size modulo of 0x200 bytes.
ImageSize = &H4% 'The executable's image size in pages of 0x200 bytes.
RelocationCount = &H6% 'The executable's number or relocation items.
HeaderSize = &H8% 'The executable's header size in paragraphs of 0x10 bytes.
MinimumParagraphs = &HA% 'The executable's minimum memory requirement in paragraphs of 0x10 bytes.
MaximumParagraphs = &HC% 'The executable's maximum memory requirement in paragraphs of 0x10 bytes.
StackSegment = &HE% 'The stack segment (SS) register's initial value.
StackPointer = &H10% 'The stack pointer (SP) register's initial value.
Checksum = &H12% 'The executable's negative pgm checksum.
InstructionPointer = &H14% 'The instruction pointer (IP) register's initial value.
CodeSegment = &H16% 'The code segment (CS) register's initial value.
RelocationTableOffset = &H18% 'The relocation table's offset.
OverlayNumber = &H1A% 'The overlay number.
End Enum
Public Sub Main()
Dim Executable() As Byte = File.ReadAllBytes("D:\Other\Cartoons.exe")
Dim StartOfTable As Integer = GetWord(Executable, MSDOSHeaderE.RelocationTableOffset)
Dim RelocationItemCount As Integer = GetWord(Executable, MSDOSHeaderE.RelocationCount)
Dim EndOfTable As Integer = (RelocationItemCount * &H4%) + StartOfTable
Dim Position As Integer = StartOfTable
Dim RelocationItemPosition As New Integer
For Index As Integer = &H0% To RelocationItemCount - &H1%
RelocationItemPosition = EndOfTable + GetWord(Executable, Position) + (GetWord(Executable, Position + &H2%) << &H4%)
Console.WriteLine(RelocationItemPosition)
Position += &H4%
Next Index
End Sub
Private Function GetWord(Data() As Byte, Address As Integer) As Integer
Return Data(Address) Or (CInt(Data(Address + &H1%)) << &H8%)
End Function
End Module
Is this the proper way to go about it?
