Reply 40 of 42, by kolderman
Anders- wrote on 2021-10-13, 21:10:
One more important point, it was around that time the floppy port disappeared from the mainboards! My amd64x2 (socket 939), came […]
kolderman wrote on 2021-10-13, 19:21:
I remember the Athlonx 64 X2 peaked around the mid-late 2000s, because upgrading meant going from socket-939 (AGP,DDR,IDE,WinXP) to the AM-socket platform (DD2/3, PCIe,SATA,Vista) meaning you needed to upgrade EVERYTHING. It was the last hurrah of 90s era tech and a lot of people wanted to keep that platform running as long as possible, and the Athlonx 64 X2 meant not only could you upgrade to a high clocked CPU, but often it meant upgrading from single to dual core for owners of the earlier single-core Athlon64s, which made a tremendous difference. Was probably the best CPU upgrade in history and no wonder prices went through the roof.
My amd64x2 (socket 939), came with floppy controller, ddr2, sata and pcie+pci 😀
Edit: I realize there's a bit of contradiction there, will have to doublecheck next time I got the case open.
Pretty sure I've seen both "939" printed on the socket as well as buying 4x1G ddr2 back in the day...
There was a lot of weird stuff around this era, like boards with both AGP and PCIe, possibly DDR1/2, but I have mainly seen DDR2/3 on latter gen boards like s775.
Reply 41 of 42, by Hoping
cyclone3d wrote on 2021-10-13, 19:23:
Ehhh, Even the Geforce FX 5950U is CPU limited in 3DMark 2001 with a Core2 X6800 below 3.2-3.3Ghz.
If going for a PCIe setup for XP, the ideal would be whatever the latest you can get XP drivers for as far as the motherboard goes... Probably an LGA-2011 with a Xeon 1680v2 or so along with a couple Geforce GTX Titan X video cards... of course I would be running XP x64 so I could use more RAM as well. The Sound card would be an Audigy 2 ZS or Audigy 4 Pro.
I've never tried to do something like that, for me XP is DX9 only and I'm not intrested in using a DX12 capable card on XP, and also I don't care about 3DMark scores, I only care that the computer can run any DX9 game maxed out at a high resolution like 1600x900 or 1920x1080 but is guess that DX9 cards aren't capable of this. Like I said, I never tried it, because most games released after Win Vista launch that work on XP will also work on Win7 and sometimes they have a DX9 and a DX10 renderer, and is cheaper to asemble a computer for Win 7 because of the driver support and hardware availability.
Of course everybody has it's point of view, it's only my opinion.
Reply 42 of 42, by subhuman@xgtx
It's a crap platform and as much of a bad purchase decision as it was 10 years ago. Any Sandy Bridge/Ivy bridge chip ran full circles around them in about every possible aspect
