First post, by eL_PuSHeR
Hi everyone!
For anyone of you who are still using TNT2 cards I must inform that detonator (ForceWare) driver version 7x.xx and up don't support TNT2 anymore. A Geforce 256 is the bare minimum.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 6, by Snover
I would say this is patently untrue since I've installed the 71.xx drivers on several TNT2s without malady. It won't automatically install them from the ForceWare installer any longer, but they can still be easily put into place if you manually specify the location of the driver.
Yes, it’s my fault.
Reply 4 of 6, by DosFreak
Yeah, Guru3D has been including modified .INF's with TNT support for some time now. Haven't tested the 60+ dets on TNT hardware but I don't see why it wouldn't work. Of course there's always the usual incompatibilies that newer dets bring to older hardware but that's another story.
Make your games work offline
Reply 5 of 6, by eL_PuSHeR
Thank you very much Snover and DosFreak. I will tell my friend he can install them by manually specify an .inf location. 😎
Intel i7 5960X
8 GB DDR4 (2100)
