First post, by robertmo
according to:
https://www.minitool.com/backup-tips/upgrade- … ing-windows-292
method 2
case 1
Looks pretty simple.
Anyone tried that?
Reply 1 of 3, by robertmo
in case the site goes down:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\msahci -> Start -> 0
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\storahci -> Start -> 0
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\pciide -> Start -> 0
Reply 3 of 3, by robertmo3
If you choose to install Windows 11 on a device that does not meet requirements, you can create the following registry key values and bypass the check for TPM 2.0 (at least TPM 1.2 is required) and the CPU family and model.
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\Setup\MoSetup
Type: REG_DWORD
Value: 1
https://support.microsoft.com/en-us/windows/w … 8b-2ce77ac7c70e
