First post, by LSS10999
I'm still experimenting with multibooting on my RUBY-9719VG2AR, and am using RUBYISA to make the ISA slot usable for my sound card in DOS.
For now I would load RUBYISA as part of the DOS startup process, but I'm not sure if I really need to run RUBYISA every time... I don't know if the configurations made to the LPC/ISA controller would stick across reboots so other OSes (like Windows and Linux) can also benefit.
I came across this thread (as well as the same thread on MSFN) about someone trying to get the WSS portion of the Orpheus in the ISA slot working on Windows XP, and from the context it seems the rest of his card was already working as there were no exclamation marks in the Device Manager, and that he also said the card was working in Linux as well (including custom WSS ports).
I even tried looking into my board's BIOS blobs to see if there are any code block related to configuring the LPC/ISA controller, but I haven't found anything that matches the register addresses yet (according to the corresponding datasheets). Maybe I need to look into the BIOS blobs more thoroughly... I couldn't find any useful hints from other AMI BIOS modding tools I know, either.
So do I really need to run RUBYISA every time the system boots, or that I only need to run it once and it'll stay, maybe until a hard reset (or power cycle), and then it can be used even by other OSes afterwards?
