Nikoh wrote on 2023-07-13, 10:01:
I don't know other nfs clients for dos, could you tell me which ones are the most used, if any?
Sun PC-NFS was the original NFS client for DOS from the company that originally developed NFS - I guess this might have been the most "popular". Beame & Whiteside also had a DOS/Windows 3.x NFS client which Novell licensed and included in their LAN Workplace product of Unix connectivity/IP tools for DOS/Windows workstations so this likely wasn't uncommon either.
But I don't know that any DOS NFS product was ever truly popular though. In 1993 NetWare had 66% market share, with the rest going to Windows NT (8%), IBM LanManager (7%), Banyan VINES (6.5%), Artisoft LANtastic (4%), DEC PathWorks (3.5%) and "Other" (5% - NFS and other products).
So DOS NFS clients were really just a "compatibility" product. You've already invested a pile of money in expensive UNIX Workstations and Servers and now someone needs a PC running MS Office. You want that PC networked but its not worth setting up a dedicated server for it so you buy some NFS client and just hook it up to the existing network of UNIX machines. The user experience will be worse than if you'd setup a proper PC server but that's acceptable given you're only networking a handful of machines.
If you had a lot of PCs you'd almost certainly skip NFS on PCs entirely and instead run a NetWare server. If you still wanted to provide some file sharing between the PCs and UNIX machines then Novell NFS Gateway lets NetWare mount an NFS share and re-share that to other machines over the usual NetWare protocols, while the Novell NFS Server lets UNIX machines access the NetWare server via NFS.
