Reply 400 of 419, by bjwil1991
Speaking of, I'm guessing the JEMM386 (FreeDOS version of EMM386) is still a no-go, eh? I might do a build for it, but it's been a long time since I attempted that.
Reply 401 of 419, by danyetman
I have a nice Win98SE machine:
P3B-F with latest firmware to allow 1.4GHz Celeron on Slot-1 Adapter
512MB RAM
Audigy 2 ZS (real SB0350) with the Control Unit and MIDI/Gameport bracket
Now, I built a few MT-32PI units utilizing the BulkyMIDI-32 project, and under windows, they work a treat. I've got the MT-32PI connected via a nice MIDI-DIN15 adapter, with a Gravis Analog Pro plugged in behind it. My Joystick works perfectly, so I know for a fact that the connection to the output bracket works fine, and I can select Audigy's MIDI under Windows 98SE and have the MT-32PI kick audio directly to my speakers, and it sounds and works beautifully.
Here's my problem - SoftMPU does not and cannot seem to recognize the Audigy in DOS. I've installed the correct Drivers, used the Audigy1-2 DOS patch, done the SB16 emulation trick, everything. I've got the Audigy set up to have IRQ9 in the BIOS, and SBEINIT.COM sees it recognizes it. If I don't use the patch, then SoftMPU will never seem to see that the card exists, regardless of what IRQ I tell it to use.
However, regardless as to whether I use MIDI input or try to connect my MT-32PI via a USB-Serial with a Null Modem Adapter, under DOS, I get no MIDI activity at all. I've even made sure to match SoftMPU's 38400 baud rate, with no effect. I'm tearing my hair out here - I'm quite the capable technophile, and I've been using Windows since the 3.1 days, but I'm at the point where I'm about ready to simply buy a PC-MIDI card (whenever the hell they're back in stock) or build a HardMPU card myself.
I see that my card is supposedly supported, and yet I get bugger all. I could use some help and advice, as the documentation seems to assume levels of success that simply don't exist in my use case.
Reply 402 of 419, by digger
bjwil1991 wrote on 2022-10-14, 01:36:
Pre-release versions of Jemm now include support for ISA DMA port trapping, as well as a loadable module that adds partial emulation of QPI, QEMM's API.
This was added for the SBEMU and VSBHDA projects, but since SoftMPU also supports QEMM, it might work with this as well.
At the time of writing, the most recent pre-release of Jemm is v5.84pre2.
I know the original argument against supporting Jemm was the fact that implementing SoftMPU as a JLM would require rewriting it in a substantially different way than what's currently needed to do port trapping through EMM386 and QEMM. But this new QPI emulation module for Jemm might pose a solution to that problem, since it would effectively make Jemm "compatible" with QEMM, at least as far as port trapping is concerned.
So what someone here could try:
  • Update Jemm to version v5.84pre2 on your FreeDOS installation
  • Make sure that either Jemmex or Jemm386 gets loaded on boot
  • Load the QPI emulation JLM with the command
    JLOAD QPIEMU.DLL
  • Try running and using SoftMPU, which will hopefully detect the presence of QPI and use it as it would if QEMM were loaded
I could set up a test system to try this on, but it's late. I might have more time for this during a weekend.
If anybody else reading this is willing to try this, I'm curious to read whether this works out of the box.
Even if not, maybe the SoftMPU developers could make the necessary improvements to make it work with Jemm with QPIEMU.DLL.
Reply 403 of 419, by Pierre32
danyetman wrote on 2023-11-21, 01:24:
I have a nice Win98SE machine: […]
512MB RAM
Is the card working with regular MIDI under DOS? ie. Forget SoftMPU for a minute, can you fire up Doom and get tunes?
Reply 404 of 419, by dJOS
512MB RAM
As that is a PCI sound card, it’s never going to work fully, if at all, in DOS.
If you want DOS MIDI, I can definitely recommend The PC-MIDI cards, they work perfectly in DOS and Windows.
The impossible often has a kind of integrity which the merely improbable lacks.
Reply 405 of 419, by danyetman
Eugh. I've been waiting for a PCMIDI in stock notification for a while.
Supposedly, the Audigy 2 ZS IS compatible with SoftMPU, according to the Github wiki. I'm at the point that I might just grab a cheap CT4520 or something...I just didn't want to eat up my only ISA slot in the motherboard with another sound card.
Reply 406 of 419, by dJOS
danyetman wrote on 2023-11-22, 03:24:
In that case, your best bet is to find a decent ISA sound card that doesnt suffer from the hanging note midi bug.
I managed to bag one of the Yamaha Audician 32 cards (OPL3 + SB support) a few years ago and it's been a great card for most things.
Reply 408 of 419, by dJOS
danyetman wrote on 2023-11-22, 03:52:
Just bought a YMF718 from ebay. I'm tired of screwing with the Audigy.
https://www.ebay.com/itm/126192277090?mkcid=1 … emis&media=COPY
Nice, that has the same chip as the Audician 32 Plus that I have.
Reply 409 of 419, by danyetman
Which is precisely what I researched and what my criteria was. I didn't want a crippled Soundblaster, wasn't going to shell out for an AWE64 Gold, needed something that would fill in for the indeterminate availability of the PCMIDI, and was ABSOLUTELY BLOODY NARKED by the Audigy 2 ZS' seeming inability to function in complete contempt of what the Github repo claimed. I spent two weeks trying different settings. I'm done with that frustration.
Reply 410 of 419, by dJOS
IIRC, the software doesnt fire up a bunch of bloated TSR's either - it just runs a config util at boot.
Reply 411 of 419, by danyetman
At some point, I might wind up building a HardMPU-WT card, just for the hell of it. I built 5 BULKYMIDI32 systems, and I should probably pair them with HardMPU-WT cards before I offer them for sale.
Reply 412 of 419, by dJOS
Nice, I’m currently adapting the picoGUS design for the Tandy 1000 EX/HX computers and adding in multi-IO functionality while I’m at it.
Reply 413 of 419, by danyetman
I looked at the picoGUS, but while I have a bunch of picos on hand, I generally don't like the Gravis Ultra Sound, and my picos are mostly earmarked for Gamecube bootloader mods, anyway.
Reply 414 of 419, by dJOS
Yeah it’s not my first choice either. The main reason for using it in my case is it gives you Adlib sound and CMS / GameBlaster on an XT class machine.
The Tandy sound is great, but Adlib has better support.
Reply 415 of 419, by danyetman
...and of course, NOW I get a notification that the PCMIDI is in stock. Oh irony.
Reply 416 of 419, by dJOS
danyetman wrote on 2023-11-22, 23:50:
🤣, I have one and there’s no noticeable difference between the midi capabilities of it and the Yamaha card.
Reply 417 of 419, by Pierre32
Well except the PC MIDI card doesn't need SoftMPU. Buy it 😁
Reply 418 of 419, by dJOS
Pierre32 wrote on 2023-11-23, 02:03:
I don’t recall needing SoftMPU on the Yamaha cards as they are MPU401 Compliant.
But to be honest it’s been a while since I used mine for MIDI.
https://youtu.be/2_L_1tvH1Ew
Reply 419 of 419, by appiah4
YMF718 is certainly not an intelligent mode MIDI chipset.. Depending on your use case you would need SOFTMPU with it.
