Reply 380 of 444, by elianda
- l33t
I have currently no setup with 386MAX, though if you try then change the memory manager detection part to be skipped and default to the EMM386 way. If it is fully compatible then this should do.
If that works we have to adapt the memory manager detection a bit. It would also helpful to know which version of 386MAX was the first to support the port trapping API.
Youtube Channel
