First post, by Dokka
Some objects in Project IGI are heavily shaded when using dgVoodoo2, which is not observed in real DirectX. I don’t know, maybe dgVoodoo2 renders more correctly, but in some scenes the game looks darker than in the original render
264.78 KiB
253.03 KiB
358.49 KiB
380.67 KiB
Reply 2 of 5, by Dokka
Dege wrote on 2023-12-18, 16:20:
Could you plz attach some savegames here, for the affected locations? So I could check it out some day.
Yes, sorry, I didn’t think about saving, here is the file you need, you need to place it in the game folder.
Screenshots taken from missions: Mission 2 Sam Base and Mission 7 Border Crossing
But even at the very beginning, in the first mission, you can see a darkened road that differs from the original.
project igi save file.zip
1.31 KiB
28 downloads
423.91 KiB
416.14 KiB
Reply 3 of 5, by Dege
Thanks, could you have a look at this version plz?
http://dege.fw.hu/temp/dgVoodoo2_82_2_projectigi.zip
I couldn't find the locations you posted but anyway, the lighting on the weapons and other non-static objects was wrong in the first place.
I made a fix and checked out a few locations, it seems to be good for me now.
Reply 4 of 5, by Dokka
Dege wrote on 2023-12-19, 19:38:
Thanks, could you have a look at this version plz? […]
Cool! In this version, the lighting in the game works fine. Thanks for quickly fixing the problem.
The only note is that if you select dx11 in the dgVoodoo settings, the game lags a lot, on dx12 everything is fine, but Afterburner monitoring does not work. However, this is not critical and probably the problem is on my side.
