Reply 20 of 27, by ZellSF
PAL TVs definitely had scanlines, you probably just weren't thinking about it. Obviously 288p scanlines are thinner than 240p scanlines. 240p/288p being the gaming resolutions, obviously when displaying TV content it would be 480i/576i, which would have much less visible scanlines.
Reply 24 of 27, by De-M-oN
You can configure GZDoom to be quiet accurate.
Or try GLBoom, or Crispy Doom. There is sure a sourceport which works for you.
Or try some troubleshooting. No one has to suffer through dosbox for an id game 🤣
Reply 26 of 27, by ZellSF
Not sure you can complain that he's going off-topic after you specifically joined in on it? You were talking about PrBoom and GZDoom, which can't run Hexen II either.
Also with the right settings I doubt most people could tell GZDoom and DOS Doom apart most of the time.
