Outwars Support?
First post, by StrikerMan780
Noticed that GOG.COM released Outwars: https://www.gog.com/game/outwars
However, the wrapper that they use for DirectDraw/Direct3D is... well, crap to say the least. It doesn't handle Indeo Video whatsoever, so you don't get cinematics in-game or in the menus, and there's a bunch of other issues. Using DDrawCompat fixes almost everything, but you're forced to 640x480, which is no bueno.
DGVoodoo2 would be my go-to, but it has problems with the mouse in the menu, and it also doesn't support Indeo. I tried GDI hooking, but it just kind of causes seizure flickering.
Is it possible that some things could be done to improve the situation?
EDIT: Submitted an issue here with more info: https://github.com/dege-diosg/dgVoodoo2/issues/70
Reply 1 of 3, by ZellSF
Use Peixoto's patches v0.6 for this game.
(it would obviously be good if this were working in dgVoodoo, but Peixoto's patches is the best way to play the game currently).
Reply 2 of 3, by StrikerMan780
Unfortunately Peixoto's patch doesn't work with the changes for music in the GoG version. (It has exe edits to allow music from both CDs to play correctly.)
Reply 3 of 3, by ZellSF
Use the latest version actually, the problem I had with that was something that was my fault.
But where can I test music from disc 2? Peixoto is aware of it, so I sort of doubt he broke it.
