eddman wrote on 2023-09-22, 18:48:
Without those it takes quite a while to determine which exact d3d version is used, specifically when it comes to D3D6 and older. It becomes even more difficult when games call different interface versions.
In fact the version cannot be determined. You can query different versions of interfaces for DD/D3D objects at the same time. So, you can have a Direct3DDevice2 and Direct3DDevice3 interface pointing to the same device object. The same is true for DirectDrawSurcface and all other DD/D3D objects.
For example, creating a DD surface with a DirectDrawSurcface4 interface can only be achieved by creating a surface with a DirectDrawSurcface interface and query for DirectDrawSurcface4 through that.
And then either release the old one or use both, for the same object.
I've seen games that load both d3dim700.dll and d3dim.dll.
In some cases, even when a game only loads d3dim.dll, it still queries different Direct3D interface versions, for example both Direct3DDevice2 and Direct3DDevice3.
d3dim dll's are not loaded by the game directly, that's done by ddraw.dll when a D3D interface is queried. d3dim700 is probably for D3D7 specific stuffs.
Direct3DDevice2 is a DX5 interface, Direct3DDevice3 is DX6. So, if a game is DX6, it can still query for both.
In the DD/D3D log I dump the object instances and not the interface instances through they are accessed, that's why there is no "version number" attached to them.
I thought it's more important than figuring out that whether 2 or more different interfaces are pointing to the same object or not.
I cannot remember if I dump the information about creating an interface object for a DD/D3D object in the spec release version, or I only do it in the debug version for myself.
If it is dumped then the interfaces for a given object can be back-tracked from the log.
Would it be possible for you to add the ability to show the interface numbers?
It could be, but it's a lot of work, I should do it for each type of objects. Maybe step by step from version to version.
I've noticed only Debugview++ shows full traces; The regular Debugview only shows dgvoodoo's own messages, and no traces. Is that normal, or is something wrong on my end?
There should be no differene. Messages and tracing are 2 different options in dgVoodoo. Maybe tracing was disabled when you used DebugView.
