Game issue
First post, by jmcinvale
I have a game called Driv3r that only runs on the main monitor.
In Windows 10 I successfully used dgVoodoo to make it run on my second monitor which worked as it should.
When I tried the same thing in Windows 11 home, the game runs fine if dgVoodoo is set to the main monitor, but crashes when set to the second monitor.
There a solution to that issue?
Reply 2 of 10, by jmcinvale
Both monitors are the exact same.
I'm wondering if it's just an issue with Windows 11.
EDIT:
Got the dbg version in use and it still doesn't work.
Where do I find the log?
I'll take a video of what it does if that will help.
Reply 3 of 10, by BEEN_Nath_58
jmcinvale wrote on 2024-03-16, 19:15:
Both monitors are the exact same. […]
EDIT:
Run DebugView before running the game and use the debug dgVoodoo2 dlls. The debug output will be in debugview program. Log the output and send here
Reply 4 of 10, by jmcinvale
Got the debug done.
Wasn't exactly sure how to use debugview so I just did the whole log after clearing the screen right before starting the game and stopping the capture right after the game didn't load.
Driv3r.txt
1.58 MiB
14 downloads
Oh my graphics card is a PNY GeForce RTX™ 4080 16GB XLR8 Gaming VERTO EPIC-X RGB™
Reply 5 of 10, by Dege
TBH, it's weird. The game does not crash but quits. I can only see one dgVoodoo error in the log, but I don't know what it is have to do with the monitor. Maybe it's completely normal, but a log from a monitor on which the game is running is needed to compare the two.
Btw, your monitor rect is a bit weird:
00000016	4:29:26 PM	[21836] [dgVoodoo] INFO: Direct3D9 (00D07C70)     Device 0: Name: "NVIDIA GeForce RTX 4080", Description: "\\.\DISPLAY16", Monitor rect: (-1366, 3, 0, 771)
It's not aligned vertically with the other but it's offseted by 3 pixels. Maybe that? Or with Win10 your other monitor is the primary so this one does not have negative coordinates which the game might not like for some reason?
I don't know, but you can give it a go by experimentally change the order of the monitors, to have this one being the primary.
