First post, by FFXIhealer
Ok, so I'm on the hunt for the original DOS program files (NOT the WAD files, I have those already from a LONG time ago and from the Win9x versions of the game) to run on my retro systems. Specifically because the Win9x versions don't really run all that well on a 200MHz Pentium system, but will run fantastic in the original DOS. I've bought the games in the past back in those days (~1997-ish), but have lost the actual files to time. I'm only recently getting back into all of this.
If this counts to the mods as "software piracy", then I apologize and I will drop my questions/request and I will fully understand if the thread is locked and/or deleted. I'm not trying to pirate software. I'm just trying to find the Doom and Doom2 software files WITHOUT DOSBox and WITHOUT the Windows9x components, etc. I'm talking the old old old original DOS stuff, because I want it to run natively on the systems. All the stuff I've been able to find on-line have been the Win9x files/packages.
Reply 1 of 17, by BitWrangler
I believe for Doom it is the original levels WAD file that is not distributable, but the executable is the same as the DOS shareware version. So if you've got the official wad, just install shareware, copy the full version wad over it and you should be good to go. Not sure what to do about Doom2 though.
Reply 2 of 17, by dr.zeissler
They changed the soundengine from the early Doom1 to the later Doom1 (1.66..) and used it in Doom2 too.
The early soundengine had no problem with ESS-Solo1 in plain Dos on intel-Chipset, the later one never worked on that soundcard in such a setup.
Reply 3 of 17, by Joseph_Joestar
FFXIhealer wrote on 2021-11-21, 15:54:
GOG has the DOS version of Ultimate Doom: https://www.gog.com/game/the_ultimate_doom
It's packaged with DOSBox, but getting it to your retro PC is pretty easy. Simply install the game on your modern system, then copy the installation folder over to your retro rig. Remember to use 8 characters or less for the folder name. Before that, you may want to delete any files longer than the standard 8+3 character limit. These are not needed for running the game under actual DOS.
I've been playing this version of the game on my Pentium MMX system without any issues.
Reply 4 of 17, by flynnsbit
FastDoom might be a better option especially if you already have your retail WAD files for Doom/Doom2. The compiled exe's are on github... https://github.com/viti95/FastDoom/releases
 Supported WADS
The supported wads are the following:
* DOOM.WAD -> DOOM Registered (3 episodes)
* DOOM1.WAD -> DOOM Shareware (1 episode)
* DOOMU.WAD -> Ultimate DOOM (4 episodes)
* DOOM2.WAD -> DOOM II
* PLUTONIA.WAD -> Final DOOM The Plutonia Experiment
* TNT.WAD -> Final DOOM TNT Evilution
Reply 5 of 17, by The Serpent Rider
Doom Shareware which commonly can be found today is using Doom II updated engine v1.9.
Reply 6 of 17, by chinny22
dr.zeissler wrote on 2021-11-21, 16:47:
A patch exists to downgrade 1.9 to to v1.1 https://www.doomworld.com/idgames/utils/exe_edit/downgrd
I used it for the 3 screen -node switch but it also reverts map changes back to 1.1
Maybe it also downgrades the soundengine?
Reply 7 of 17, by FFXIhealer
Well, this mini-project is now going to have to wait. My Pentium 1 Win95 system now won't boot due to some driver issues regarding the IDE ports on the motherboard. Looks like a fresh re-install is in my future, before I can even begin to try to put games on it.
Reply 8 of 17, by FFXIhealer
Ok, so I spent over an hour in DOS deleting the C:\Windows folder file by file, folder by folder, command by command until it was nuked and gone and then reinstalled Windows 95. It's working perfectly right now. I guess now I can worry about this whole Doom2 thing again. 🤣 Win9x and freakin' drivers, I swear.
Reply 9 of 17, by BitWrangler
Get a linux boot disk that lets you do an attrib -r -a -s -h on it all , then just rm that sucka.
Reply 10 of 17, by FFXIhealer
Too late. It's already done. The long way. 🤣 I just put some Twitch streamer on while I was doing it. Gave me a very clean folder for a new Win95 install.
Not that it's relevant, but this system I actually did a "build" stream on my Twitch channel too, but I think it was too long ago and the VoD is no longer there. It was fun, but I don't have the camera and lighting setup that Phil's Computer Lab has, so it probably looked and sounded like an amateur was doing it.
Reply 13 of 17, by 0x90
As mentioned above, Doom shareware (and old 3-episode registered version) and Doom 2 use the same executables. First version with complete Doom 2 support is v1.666. There are actually two slightly different variants of v1.666 (I think one was bundled with Doom 2, one you got via patching Doom 1) but it doesn't matter which you use. Neither one is the same as v1.6, though IIRC all three internally use VERSION = 106 for for demos, saves, netgames, etc.
Ultimate Doom and Final Doom need special updated executables either for the 4th episode (Ultimate), or for correct intermission and map name texts (Final).
There are actually two different versions of the Final Doom executable, the newer bug-fixed version was only ever officially distributed with the "id Anthology" package and via the "idstuff"/"idouts" digital store system.
All of the Ultimate and Final executables are still labeled "v1.9" (and internally use VERSION = 109), but they are not the same as the regular v1.9 executable or each other.
Ultimate v1.9 -> registered v1.1 downgrade patch does downgrade the sound system (DMX) too, it is wholly contained within the main doom.exe (or doom2.exe) file.
Btw. older versions of the sound system used to do hardware mixing of sound effects on GUS, but this was unfortunately removed in an update, around Doom v1.4 IIRC. The newest versions of Doom (since v1.8 IIRC), on the other hand, include undocumented direct support for Ensoniq SoundScape, and WSS / Crystal Codec compatible cards (not present in setup, need to edit default.cfg by hand).
You can get many different versions of vanilla DOS engine binaries for Doom, Heretic, Hexen and Strife from here:
https://github.com/Doom-Utils/iwad-patches/tr … /vanilla-engine
Reply 14 of 17, by matze79
Play some Wood instead 😀
65.25 KiB
Reply 15 of 17, by Cyberdyne
In reality Doom 1.1 has better sound, varable pitched sound. And it is little bit faster in slow machines.
Reply 16 of 17, by MAZter
Here some Dos ports, from oldest to newest:
Doom Plus:
http://iddqd.ru/new?find=Doom+Plus
TasDoom:
http://iddqd.ru/new?find=TASDoom
MBF (Marine's Best Friend):
http://iddqd.ru/new?find=MBF
Dos Doom:
http://iddqd.ru/new?find=DOSDoom
Boom:
http://iddqd.ru/new?find=Boom
SMMU:
http://iddqd.ru/new?find=SMMU
ReBoom:
http://iddqd.ru/new?find=ReBoom
FastDoom:
http://iddqd.ru/new?find=FastDoom
ZDoom:
http://iddqd.ru/new?find=ZDoom
Reply 17 of 17, by RaiderOfLostVoodoo
matze79 wrote on 2022-02-19, 16:15:
I saw this a few days ago, but didn't knew where to post it on Vogons. 🤣
Wood, the 1993 classic!
