First post, by Exploit
I have created a library with the help of wlib.exe. The object files were created with jwasm.
wlib testlib +newline +upcount +dncount
wlib testlib
See screenshot wlib.png for output of listing.
Now i tried to extract an object file from the library again the way it is described here:
https://users.pja.edu.pl/~jms/qnx/help/watcom … tractingAModule
Thus i entered:
wlib testlib :dncount
This didn't work, see screenshot extract.png.
Then i tried the following with the same error:
wlib testlib :_dncount
In all cased i got the error:
Error! Cannot find file ':_dncoun.obj'
    7.42 KiB
    9.88 KiB
Reply 1 of 1, by Exploit
Okay, i found the error.
It seems to be, that the manual is wrong or the operator for extraction was changed from : to *.
It is not :objectname, it is *objectname
This works:
wlib testlib *dncount
