First post, by Rav
Hi there, Yesterday I wanted to replace my windows Nt4 install for a NT3.51 Install, on my 486
I had 2 partition : Main 1500MB DOS partition with MSDOS 6.22 and a NTFS partition with NT4 inside an extended partition.
I deleted the NTFS partition and the extended partition then I deleted the NT related file in my dos partition, Then I did the fdisk / mbr and sys c: to get rid of the NT4 boot menu.
Then I moved NT3.51 i386 folder to the DOS drive with mTCP FTPSRV then I proceeded to try to install it.
It did the usual NT thing and proceeded to copy a bunch of files on the C drive then it rebooted.
I only get a flashing cursor when the PC boot.
So I then booted dos from a floppy, got rid of the NT files from C, did the fdisk/mbr, sys c: again so DOS can boot from the hdd again.
Tried another version of NT3.51 from internet archive. Same problem.
I begin to think that it could be something not compatible with NT3.51 so I just copied the NT4 i386 folder over to just reinstall NT4 instead.
Flashing cursor on boot again!
Then I backed up everything and used DBAN to zero out the hard drive and retry with NT3.51
I used fdisk to make a 600MB DOS partition, formated it with /s to let a chance to NT to detect the DOS so I have the menu, copied the i386 folder over, did the first install phase again...
Flashing cursor
I did try a few other way including scanning my DOS floppy disk with f-prod with 2009 defs in case I save something funny littering in my boot sectors, Tried with all the kitchen sink loaded, with only 386MAX, then with only Himem+smartdrv, Then with nothing from config/autoexec loaded, I still only got the flashing cursor on boot.
NT4, I installed it last month without issue so I don't know why it does not want to install anymore.
Hardware change since I installed NT4 successfully and now:
* Installed a Media Vision Pro Audio Spectrum 16
* Installed a 3COM 3C509
* Installed 128KB of L2 (waiting for more chips, first batch have 40% defect and did not get enough to fill all the bank.
* Went from 52MB of ram to 16MB of ram (I have only 128K and I wanted it all cached). I do plan to come back to 52MB this week as I should receive about 50 more sram chips.
I was running the old version of NT4 without issue with all hardware installed.
Could it somehow only affect it during installation? The sound card have a SCSI interface but nothing plugged on it, I know that NT* installer detected it because it show it while the initial install phase.
Should I remove all the ISA cards and try again?
In all install tentatived, I ran winnt /b from the i386 folder copied on the DOS C drive. I do not have a CDROM unit, yet.
