TitaniumGL
First post, by Geri
TitaniumGL is an OpenGL driver (/implementation) which on Windows acts as an OpenGL to D3D9 wrapper. With the help of TitaniumGL, games using OpenGL (up to 1.4) can be used on computers with no OpenGL drivers. If no hardware 3D acceleration is present on the system, TitaniumGL uses its built-in software renderer as backup.
I rewrote TitaniumGL in the last years. I have finally came up with a 64 bit windows dll as well. The new version is much faster, and efficient, ready to be used with 2D and 3D video which use more polygons than their earlier versions. Those who remember the old TitaniumGL, this new version picks up the line where the old one stopped. License is changed, new version of TitaniumGL can be embedded into free or commercial games due to a new bsd-type license. Donations are welcome regardless.
-64 bit Windows version released.
-New command batching system.
-D3D acceleration autodetection and software fallback system.
-New, faster D3D subsystem.
-New software renderer - approx 3-8x faster than the old one.
-Switching to different license
-Fixed some missing BGR, BGRA, ABGR formats when using glDrawPixels
-Improved stability with Windows 98
-TitaniumGL got fine tuned to support newer type of video games.
-TitaniumGL now supports classic OpenGL game builds released after 2020.
-Fully separated API and state tracker.
-New (less buggy) lighting code.
-Removed some ancient unused extensions.
-Minimizing D3D API interaction for better speed.
-2x-3x faster texture uploading.
-New batching system supports up to 32 threads.
-New threading system which scales better up to 3-4 cores.
-Fixed broken Quad Strip implementation.
-TitaniumGL will do less memory copy operations to send the vertices to the gpu than before.
-TitaniumGL will optimize and simplify d3d vertex formats for more efficient operation.
-Faster tesselation code.
-Efficient pointer caching for less intensive utilization of memory management.
Download TitaniumGL:
http://users.atw.hu/titaniumgl/index.html
Reply 1 of 35, by Geri
Bugfix and new Win95/98/Direct3D7 backend
-New DirectX 7 based Win98 test version released for old DX5/6/7 era graphics cards.
-Small bugfixes in light and material code.
-Fixed bugs with point and line rendering.
-Added support for SGIS multitexture (not in extension list for now).
-Decreased API overhead a bit in D3D mode when loading textures.
-Optimized the code on single-core systems.
-Fixed some issues with multitexturing.
-Fixed a bug resulting crash when resizing the rendering window in Windows in software rendered mode.
-Fixed some integer types when loading a texture.
-Added some missing functionality to glGet.
-Added glGetBooleanv.
-UV coordinates were lost sometimes, when rendering from lists.
-VBO code got silently broken due to compiler update. Problem solved.
-Fixed a bug when uploading IBO data with glBufferSubDataARB.
-Added some missing functionality to push and pop attrib and clientattribs.
-Fixed ALPHA test functionality in D3D wrapper mode.
-Fixed flickering and box bugs in Medal of Honor.
-Fixed vegetation alpha issues in newer versions of Super Tuxkart.
TitaniumGL the OpenGL to D3D wrapper:
Reply 2 of 35, by Deffnator
there are plans to make it work with dgvoodoo2 d3d9 dll's?
it would do wonders with dgvoodoo2's tesselate mode like Neverwinter Nights 1/NWN Diamond edition on GoG who supports ATI Truform, as other GL games off Raven's thread.
Reply 3 of 35, by BEEN_Nath_58
I remember a game Abashera Revamped displayed white under native Nvidia OpenGL driver. i wonder how this one does, the only one that worked then was mesa3d
Reply 4 of 35, by BEEN_Nath_58
@Geri, I was testing Abashera Revamped with TitaniumGL and it has problems. Can you check out what's up with it? Its a free game accessible here: http://www.caiman.us/scripts/fw/f2203.html
A screenshot for reference:
Reply 5 of 35, by Geri
Deffnator wrote on 2023-07-21, 20:07:
Yes. I spoke with dege about this, but mostly about the d3d7 backend. He said he will test it (he probably didnt tested it yet).
I will also test to see whats going on, eventually. Currently i have no information about dgvoodoo compatibility.
TitaniumGL doesnt supports truform, and TitaniumGL can't expose any vertex pipeline features 1:1 to directx. TitaniumGL is not an usual simplistic wrapper that converts the calls to equivalent calls of an other api, instead, it does the entire functionality is implemented by hand, therefore its not possible to redirect vertex process states without reimplementing the given featuret from 0 in full software (which in the case of truform, i am not planning to do). Even if dgvoodoo can force truform even if the executed game software doesnt utilizes it, it will still not work, because some extra surface data (such as welded normal vectors) are already processed by the lighting system and annihilated at the point where d3d receives the vertex data.
Reply 6 of 35, by Geri
BEEN_Nath_58 wrote on 2023-07-22, 04:42:
I will put the game to the test software pack, and will take a look when i will create a next version.
It could be a strange texture format which causing the problems, or it could be a missing texture state bit somewhere.
I will debug it, and if its a simple fix, i will patch it.
Reply 7 of 35, by BEEN_Nath_58
Geri wrote on 2023-07-22, 09:38:
I will put the game to the test software pack, and will take a look when i will create a next version. It could be a strange te […]
I got something here: https://web.archive.org/web/20100928045025/ht … com/game_forum/
Reply 8 of 35, by Myloch
Ciro der dinosaurier: 32bit opengl -> it works but ingame black screen , only hud and pop up messages are visible.
@Geri: PM if u want the game for private testing purpose.
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Reply 10 of 35, by Sh1nRa358
It makes the game display missing graphics in Final Fantasy VI (old version)
Reply 11 of 35, by Radeux
Hi Geri! I used to do testing on ThunderGL way back in the day! I've collected almost every video card ThunderGL had support for at this point too! Even the Wildcat 4xxx that you made the final Dec 2008 build for. I use ThunderGL on Doom 3 with Voodoo 5 on a regular basis.
Since then I've played with TitaniumGL on laptops with weak GPUs, your work rocks the house!
Anyway, awesome to see the old beast got a new build. I'm available for testing again.
You name the card and I probably have it, as well as a working system it can thrive in.
Reply 12 of 35, by Geri
Helo Radeux, i am glad you enjoying my work. I indeed canceled that project in 2008 in favor of this (but sometimes i am thinking about restarting it). Today i have updated TitaniumGL again, important bugfixes had to be done.
Reply 13 of 35, by Geri
Regular bugfix release
-Fixed a bug with AMD GCN based graphics cards, causing far objects to be hidden from the screen.
-Fixed the slowdown on computers with more than 8 cores.
-Fixed some graphics glitches in Quake2.
-glGet now can read the current color.
-Fixed a missing texture format when using unsigned short.
-Fixed some rounding bugs when using non-floating point colors in some cases.
-Enabled GL_SGIS_multitexture extension when using the D3D mode.
Reply 14 of 35, by Geri
I have tested the game, but i was not even able to start it, the software display an opengl error message. However, i can't see any reason for it, the last thing the game does is uploading a texture, before showing the error message.
Reply 15 of 35, by marxveix
I tested TitaniumGL with my Rage XL, but the screen blinks and Quake2 text is selectable, menu works. It was with Win9x and DX9.
I have best results with GLDirect 3.0 at the moment, but its not basicly free version, only newer version 5.0 is free for everybody, but
that does not work with paletted textures and GLDirect 1.0 up to 3.0 are. Best for me so far is Mesa 3.1 that GLDirect 1.0 - 3.0 has.
Rage3 / Rage4 cards have working Direct3D paletted textures, but OpenGL does not have this and only GLDirect 1.0 up to 3.0 can do it.
Re: ATi RagePro OpenGL files
Is there any totally free tool that can maybe work, ALTOGL i have tested also and no palleted texutres there, at least version that i try.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 16 of 35, by Geri
marxveix: Thankyou for your feedback. TitaniumGL is optimized for WinXP and above. win98 compatibility is only an afterthought.
Reply 17 of 35, by Sh1nRa358
Final Fantasy 6 Remaster Steam, text not showing and graphics are showing on the black side bars when they arent supposed to be when using titaniumgl. in-game image is also darkened.
Reply 18 of 35, by Geri
Sh1nRa358 wrote on 2025-01-12, 22:56:
Thankyou for reporting the issue. Fixed most of the bugs, except the background in the battle system.
Reply 19 of 35, by Geri
-Fixed a few bugs with Final Fantasy 6 steam remake (reported by Sh1nRa358), the game is now playable
-Color management was broken in glPopAttrib
-Alpha test values are now properly returned in glGet
