First post, by buckeye
Strange, felt for sure this game would run no problem with win98SE installed. My specs:
P4 2.4 ghz.
512mb ddr333
Geforce 2 Ultra 64mb
Nvidia drivers 45.23
directx 8.1
It starts fine but once in the menu setting up a "driver" it freezes. Strangely it wakes up when I either pull the usb gamepad
or open/close the cd drive. Is this game sensitive towards faster processors? Believe the game came out in 2000 so it only
supports Pentium 2-3 and that's it? Haven't tried the 3.5 patch yet but wanted some feedback first.
Reply 1 of 9, by Sombrero
It's the nvidia 45.23 driver, it has generally good compatibility but this game is an exception. Give 30.82 a try.
Reply 2 of 9, by Gmlb256
^ Yep, I have heard that the Detonator 45.23 have compatibility issues with certain NFS games. Using an older driver helps in compatibility.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
Reply 3 of 9, by Pierre32
Nothing of value to add but man, this game has been a very special headache for me on every system I've tried to run it on, from period correct 9x & XP systems through to modern.
I will look into drivers next time I am trying.
Reply 4 of 9, by DoZator
Usually it helps to lower the priority on the "Porsche.ICD" process immediately after starting the original version of the game (without patches). This is a known issue and I've had it on all Win98 configurations regardless of driver version (both 45.23 and 56.56 or higher).
Reply 5 of 9, by buckeye
Sombrero wrote on 2023-06-15, 18:18:
Thanks, will do! Tried the 3.5 patch but that did nothing.
Curious though, the game runs fine on my other win98 system which has a P3 450mhz. and Voodoo 3.
Reply 6 of 9, by kolderman
Gf2 can use super early drivers, like 8.04 or something. They tend to perform better too.
Reply 7 of 9, by Gmlb256
kolderman wrote on 2023-06-16, 12:58:
The whole situation with the CPU overhead only applies for Pentium III CPUs and below.
Reply 8 of 9, by VDNKh
buckeye wrote on 2023-06-15, 15:31:
Strange, felt for sure this game would run no problem with win98SE installed. My specs: […]
P4 2.4 ghz.
512mb ddr333
directx 8.1
Are you using EAX? And what soundcard do you have? I had that problem too. Fixed it by creating a profile in RivaTuner that sets the process priority for the game's .exe to "Idle", and launched it through RivaTuner. I think disabling EAX also fixed it, but this was years ago.
Reply 9 of 9, by buckeye
Ended up trying the 30.82 nvidia drivers and it's working fine now!
Didn't mess with the sound settings, left at default. Sound card is 1st generation Audigy.
