First post, by NightShadowPT
I'm trying to make my boot as clean as possible and I'm using the Silent option (whenever available) when I install and configure my devices on Autoexec.bat and config.sys.
Nonetheless, not all of them seem to have the silent option and the verbose is displayed on screen.
On autoexec.bat I found that if I redirect the output to "null device" (using the ">nul" command after each line) I can avoid seeing the verbose, but on config sys I am not aware of anything similar I can do.
I am currently struggling with the CD-ROM SCSI device drivers from Adaptec:
ASPI7DOS.SYS
ASPICD.SYS
As I cannot seem to find the option to make them silent...
Any suggestions?
Thanks
Update: Corrected "console" to "null device" - thanks to analog_programmer for the correction.
NightShadowPT
Compaq Deskpro M 486/66 - 64MB Ram - Compaq QVision 1MB - Orpheus II Sound
Card - 4GB SCSI HDD + 4GB CF Card - SCSI CD-ROM Plextor PX-32TSi - Adaptec WideSCSI AHA-2740W - 3COM Etherlink III Card
Reply 1 of 7, by mattrock1988
Wow so I just had this same question I was asking myself when working on an old Windows 3.1 system.
I did some research and I found out what should be the solution, and I hope this helps!
There's a tool called "Blackout" which you can download from the simtel archive.
https://ftp.zx.net.nz/pub/archive/simtel.net/ … il/blackout.zip
From there, you extract the EXE to your location of choice, then invoke the file twice. Once towards the beginning of CONFIG.SYS as a DEVICE parameter, and again towards the end of your AUTOEXEC.BAT.
What the tool does is it blanks the screen while routines are carried out, then re-enables video output on the second execution of the tool.
Retro PC: Intel Pentium III @ 1 GHz, Intel SE440BX-2, 32 GB IDE DOM, 384 MB SDRAM, DVD-ROM, 1.44 MB floppy, Nvidia GeForce 4 Ti 4600 AGP, Creative SoundBlaster AWE64 Gold, Aureal Vortex 2
I only rely on 86box these days. My Pentium 3 PC died. 🙁
Reply 2 of 7, by NightShadowPT
Thanks for the tip.
Although blacking the screen was not exactly the option I was looking for, beggars can't be choosers 😁
To be honest I have not found any other options, so this will be a huge step in the right direction.
Thanks again.
NightShadowPT
Reply 3 of 7, by mattrock1988
No worries! Glad I could help.
Reply 4 of 7, by Malik
Out of topic, but :
I for one, love to see the outputs from my Autoexec.bat and Config.sys files. I do try to choose the minimal info switch as the parameter if available, if the output is too messy.
Reply 5 of 7, by Harry Potter
Well, I like both the splash screen and the verbose info. I sometimes used to press ESC during startup to display DOS's output. I also used to use XrX to change the splash screen. I have some C64 game screenshots as splash screens and can post a link if desired. I can also post a link to the XrX logo utilities and included splash screens, but they aren't mine. 😀
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 6 of 7, by analog_programmer
NightShadowPT wrote on 2022-10-14, 17:01:
On autoexec.bat I found that if I redirect the output to the console (using the ">nul" command after each line) I can avoid seeing the verbose, but on config sys I am not aware of anything similar I can do.
Let's make something clear: " > nul" doesn't redirects to "console", but to "null device", and thus you don't see the output on the monitor (console output). To redirect output to console (which you don't want) use " > con".
I've never tried " > nul" in "config.sys" and I had no idea that it doesn't work there, but it's the most simple and convenient solution for blackin' out the output from "autoexec.bat" commands.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 7 of 7, by NightShadowPT
analog_programmer wrote on 2023-08-22, 03:43:
Indeed, you are absolutely correct.
I have updated my original post for accuracy.
Thanks
NightShadowPT
