First post, by Simmerhead
Hi!
What software do you folks recommend for ripping floppy and CD images? I have quite a stack of old driver floppies and CDs that I want to upload to the Internet archive, and I want som images of CD games to mount with DaemonTools in Windows 98 to avoid that spinning CD annoyance.
Simmerhead - Old is gold!
Reply 1 of 7, by paradigital
ImgBurn was always my go-to for CD/DVD images.
WinImage is a good option for both Floppies and CD/DVD, but it’s not freeware.
Reply 2 of 7, by wbahnassi
WinImage... as long as you have your disks in write-protect mode to protect them from Windows, as it can pollute their original contents with nonsense-ware.
For CDs any CD burner typically has the function to rip CD images. Just make sure to use a format suitable if you want to retain additional tracks (not a problem if you are archiving driver CDs).
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, TSeng ET3000, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 3 of 7, by nfraser01
paradigital wrote on 2023-11-06, 17:17:
CDBurnerXP for CD/DVD ripping and burning (Windows). Not sure if DeamonTools requires a specific format?
I got a warm fuzzy feeling after paying my regisration fee. It was higher than I would have liked but worth it. So yes, WinImage for floppies (unless you only have a USB floppy)
HTH
Reply 4 of 7, by elszgensa
In case some of your media do have copy protection: Alcohol 120% (and a decent drive) for optical discs. If you have a machine with XP or earlier to rip on then you can even grab their free "retro edition". And for floppies there's hardware devices, e.g. Kryoflux or Greaseweazle.
Reply 5 of 7, by GL1zdA
I'm using DiscImageCreator via the Media Preservation Frontend. It works well with all kinds of images and is the only one I've got satisfying results with Multi-Mode CDs (Data + Audio tracks).
getquake.gif | InfoWorld/PC Magazine Indices
Reply 6 of 7, by Norton Commander
EMT4WIN is free and is what I used to image all my floppies.
http://www.os2site.com/sw/util/disk/floppy/index.html
Scroll down and download EMT4WIN v4.39. It run on Windows 10.
Reply 7 of 7, by MrRar
For reading and writing floppy disk images I use rawwrite. It supports retro Windows versions all the way back to Windows 95!
http://www.chrysocome.net/rawwrite
