First post, by LadyAIluros
So I finished 6 and am on to 7, but this one is being a pain. I understand this is a Knwon Thing.
I let the install make a boot disk for it because memory, and now I get a crazy large font with "Speech Card Initalization Failed. Program Terminated By Code." I ran install and set the SB settings according to my card, at least the ones that I know it loads. Does the boot disk change your Soundblaster values? I have a Vibra 16 that I know worked in U6, os I know it works okay at least on my default config?
EDIT: I realized the boot disk was not loading the sound driver so I tried running it manually after the error and now the game boots but hangs after I try to start or I let the attract screen go, so I assume it’s running out of RAM?
Reply 2 of 17, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Minimal set of bat/sys from back then I used:
config.sys:
device=c:\dos\himem.sys /TESTMEM:OFF
dos=high
FILES=40
BUFFERS=25
DEVICE=C:\PROGRAMS\CREATIVE\CTCM.EXE
autoexec.bat
PATH C:\DOS;C:\DOS\BAT;C:\PROGRAMS\MAUS
SET MGA=C:\PROGRAMS\MATROX\MON\
SET TEMP=C:\DOS\TEMP
set sound=c:\PROGRAMS\CREATIVE
set blaster=a220 i5 d1 h5 p330 e620 t6
set Midi=synth:1 Map:e MODE:0
SET CTCM=C:\PROGRAMS\CREATIVE
set lmouse=c:\PROGRAMS\maus
prompt $p$g
Mouse.exe
Don't remember which Creative card I used back then. Some SB16 or already an AWE.
Maybe the soundcard needs some software run, that needs EMS (and Ultima VII really hates EMS)?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 17, by ajacocks
I had the same issues getting Ultima VII working on my 386DX/25, back in the early 1990s. Ultima VIII is even more difficult, I could never get it enough conventional RAM.
- Alex
Reply 5 of 17, by Dominus
DOSBox Moderator
In comparison U8 is much easier as you can use emm386 again.
Reply 6 of 17, by Rwolf
Ultima 7 used a built-in memory manager that was a PITA back in the day.
The last time I played it, I think I used the EXULT mod to play it in Windows instead.
https://ultima7.ultimacodex.com/exult/
Reply 7 of 17, by Dominus
DOSBox Moderator
Or just go directly to Exult‘s site https://exult.info 😉
(I‘ve been involved with that for the last 24 years 😉)
Reply 8 of 17, by creepingnet
Honestly, I'm surprised nobody has asked about the Unisound or what version of DOS he's using (FreeDOS, Ms-DOS, DR-DOS, etc...).
Getting VII working on actual hardware is a royal PITA. It's all because of that VooDoo Memory manager which requires the computer be in "real mode" before it loads (hence the no EMM386.EXE) - since the memory driver throws the PC into a "Flat model" memory mode called "Unreal Mode" or "VooDoo Mode".
If you're using FreeDOS I found a hack/workaround to get it running on there, since either FreeCOM, HimemX, or XMGR are refusing to see memory correctly or in a way that U7 likes. Basically, you have to run the u7 module directly with P ie
U7 c150 p
or
U7 p
The problem with this though is you'll have to use whatever name you have in the game to get it working, and if there's already a savegame in progress, it'll start the last savegame. It's the same as typing "Game" for Ultima 6. I believe the "P" switch bypasses the check for starting Ultima7.exe.
I'm trying ot figure out if Ultima7.exe, intro.exe, or mainmenu.exe are what does the memory check. I think if this can be hacked/bypassed, 7 might work properly on FreeDOS finally, because I've had it running excellently with the trick I used above (using U7 p or Serpent p)
~The Creeping Network~
Reply 9 of 17, by LadyAIluros
Okay this is my current config.sys and autoexec.bat. I commented out the line about EMM and ran the memory command.
RE: Exault, I don't use Windows, all my daily drivers are Macs 😁
I am using MS-DOS 6.22 and the Unisound drivers for the Vibra 16.
I am a girl-user 😜
    911.21 KiB
    1.02 MiB
    1.66 MiB
    1.66 MiB
Reply 10 of 17, by Dominus
DOSBox Moderator
Exult, I don't use Windows, all my daily drivers are Macs
Exult is a multiplatform program, running beautifully on macOS (as I am a mac user myself).
In your config.sys, disable emm386, ifshlp.sys and the CD driver (put REM in front of the lines).
In autoexec.bat disable smartdrv and mscdex.
You need as much conventional memory as possible.
And just to make sure, did you setup the soundcard in Ultima 7‘s install.exe?
Reply 11 of 17, by LadyAIluros
Dominus wrote on 2024-02-08, 05:44:
Exult is a multiplatform program, running beautifully on macOS (as I am a mac user myself). […]
Okay that seems to have worked - I assume that every NOPC does not have spoken lines, I don't think we were there yet but I can load in and walk around and it is hell on a hard drive, wow does the drive put in work. It's a 486DX/50 so I know it has the power to run this, but it feels slower than U6 was on the same machine. (I don't know what the min spec was for U6 tho....)
Thank you!!
Reply 12 of 17, by Dominus
DOSBox Moderator
Now that you have it working, try getting smartdrive to work as well. That should work better if it doesn‘t take too much memory again
Reply 14 of 17, by Dominus
DOSBox Moderator
Yes!
Back in the days I was able to use UMBPCI to load EVERYTHING and still have enough conventional memory for Ultima7 😉
Reply 16 of 17, by Dominus
DOSBox Moderator
🤷‍♂️ if it works, it works 🤷‍♂️
