First post, by AeonG
The subject says it all. It has always irked me that in classic windows, when you drag a program file into a folder, it makes a shortcut instead. Is there any program that turns this off? If I want to make a shortcut, I'll make one by selecting it in a dropdown list.
I'm aware that CTRL C or X will bypass this, but I want it to just work without having to do that.
Reply 2 of 3, by wirerogue
just use right mouse button to drag and drop.
when released, you will be promoted for your intended action.
Reply 3 of 3, by chinny22
If you hold Ctrl while dragging it'll copy the file rather than creating shortcut.
but admittedly if doing that may as well just go ctrl c / ctrl v method
