First post, by pjturpeau
Hi there,
everything is in the title, I'm looking for a tool which would help me understand the structure of some executables (mainly MS-DOS).
I would like to avoid writing one, even if there's arleady plenty of infos available like in https://github.com/open-watcom/open-watcom-v2 … com/h/exeflat.h
Any idea?
Thanks.
Reply 2 of 9, by BloodyCactus
yeah my info-le is quite old, but should describe the main parts of LE header.
Reply 3 of 9, by bakemono
CFF Explorer is a good tool for PE files.
MZ header doesn't really contain that much information. I have a very minimal tool just to display the memory footprint to determine when something will fit in available conventional memory:
    MZINFO.ZIP
    1.3 KiB
    15 downloads
again another retro game on itch: https://90soft90.itch.io/shmup-salad
Reply 5 of 9, by BloodyCactus
infoexe for MZ comes with LZEXE packer by fabrice bellard.
https://bellard.org/lzexe.html
Reply 7 of 9, by Peter Swinkels
@pjturpeau: Out of curiousity, what do you intend to do with this information?
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
Reply 8 of 9, by pjturpeau
Mainly for learning purpose to be able to pack data to executables after the link phase.
I would prefer doing this rather than making the executable grow in size (from an MSDOS point of view) by embedding data at compilation time.
Reply 9 of 9, by Jo22
For NE there's Borland Resource Workshop 4.5, for example.
For NE/PE, Exescope is worth a try.
Other tools of this kind are Resource Hacker, EXE Explorer, PE Explorer.
    28.59 KiB
    12.51 KiB
