First post, by twood1130
I have been trying like mad to get two joysticks working properly with these games.
Hardware:
IBM 486SLC2 66mhz (386sx)
16mb ram
Quickshot 2-port joystick card
Whatever joystick is plugged into Port 1 works fine, and there are no issues. However whatever joystick is plugged into port 2 is unusable. The calibration screen in Golden Axe (press F5 at any time to access) just shows the cursor jumping around the screen.
Results in DosBox are almost identical surprisingly, so I am not sure how to go about the problem.
If anyone knows anything that could help, I would love to hear from you.
