First post, by RegTheEvil
- Newbie
I am trying to make my MIDI keyboard work with Fast Tracker 2 (version 2.09) using gameport from my YMF724 sound card. MIDI keyboard is connected to gameport with gameport-midi cable. I have tested my MIDI keyboard with AdLib Tracker 2 (version 2.3.52) and it works there. (At least I can play my MIDI keyboard. Haven't yet figured out how to use it in record mode though, but that's totally separate issue...)
Is there something I need to enable in Fast Tracker Settings to make it work? I checked 'FT2.DOC' and couldn't find anything. In AdLib Tracker I had to edit .ini-file to add support for mpu-330 interface (AT2 manual helped). After that it worked fine. In Fast Tracker settings it reads "MIDI Port 330". There are some settings for midi and most of them seem to be enabled right away. I have ticked some on and off and can't just get any life out of my MIDI keyboard in this program.
Somebody tell me what I'm doing wrong or what I'm not doing right. . .
