First post, by C0deHunter
When I launch the SETMUSE in order to set the music, I get the following choices:
Soundscap MIDI
Adlib
4-OP FM
General MIDI
Roland
None
When I choose General MIDI, or Roland, the game simply loads no music files.
If I choose *detect*, nothing happens when either of the two are selected.
If I choose *test music*, it freezes my PC.
My System specs:
PIII-800E
Abit BH-6
512MB SD-RAM PC100
AWE64 Gold
Windows 98SE
(but I am using PhilComputerLabs', *pure* DOS option to play the launch the game from a DOS prompt)
Any help would be appreciated!
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 1 of 5, by i2lgames
This game is speed sensitive. You can try shutting down the cashe with setmul or using throttle to slow down.
Reply 2 of 5, by C0deHunter
I suspected that as well. On my PIII-800, the SetMul does not seem to do anything. What are my other options for slowing down this system?
Reply 3 of 5, by i2lgames
Well the INTEL chipset, although very stable and compatible, does not work well with either setmul or throttle. I tried, a long time before, using a via chipset slot one motherboard and, while the slow down utilities worked, the system became VERY slow. The same applies to socket 370. The best thing i did is that i found a VIA MVP3 chipset motherboard with agp (a bit buggy but works nice with voodoo 3 agp and geforce2 cards) and stuck an AMD K6-300 in. Throttle works wonders and setmul is doing a good job, while still on par with Pentium 2.
Reply 4 of 5, by C0deHunter
UPDATE:
I was able to run the system perfectly with using SetMUL L1D command, instead of using Phil's (Phil's Computer LAB) per-configured batch files (i.e. Slow, Slowest, etc.), and now the game works!
Reply 5 of 5, by i2lgames
Nice! The same applies to day of the tentacle and indy 4.
