Reply 40 of 92, by maxtherabbit
- l33t
so as long as I got OS/2 2.1 I can get win3.1 app compatibility and it should run ok? sounds like we may have a winner
A downside is the device driver availability in OS/2 2.x (versus Microsoft Windows 3.x).
Back in the day, I did not own any computers with 386sx except my LTE 386s/20 notebook which is not running windows, I used microsoft word 5.0 for DOS to create notes and writing when i was at college.
My very first computers was as toys playing with hardware and 286 boards. I played games short time on 386DX when I went to college I created a 486DX 50 out of Amd 486dx 40 with VLB.
Cheers,
Great Northern aka Canada.
I'm going to try 95 for giggles, and hope that reducing the vcache to a minimum of 512kB allows the CF card to shoulder more of the burden and keep more system memory free to reduce swapping
If that runs like ass, OS/2 2.1 is on deck
wrote:I'm going to try 95 for giggles, and hope that reducing the vcache to a minimum of 512kB allows the CF card to shoulder more of the burden and keep more system memory free to reduce swapping
OK, OS/2 2.1 is on deck then.
Windows 95B is up and running just fine on this beast
I had to reflash my XUB ROM to the "386" version (was using the XT+ version before that employs the 286 instruction set) in order to get the CF card out of "MS-DOS Compatibility Mode". The 386 build of XUB contains the "Windows 95 hack" for this exact reason.
So 8MB 0-wait memory + 386sx16 + 256kB L2 cache + 4GB CF card = barely acceptable Windows 95 machine IMO
95 has built in drivers for my Adaptec SCSI card which is driving my external CDROM, and I was able to load the Advance logic ALS007 drivers for my sound card. Just need to get a driver for this Everex Viewpoint Standard VGA to enable 256 color and I'm good
wrote:So 8MB 0-wait memory + 386sx16 + 256kB L2 cache + 4GB CF card = barely acceptable Windows 95 machine IMO
It might help a lot to use a video card with Windows acceleration.
If you don't have acceleration, the CPU needs to draw everything. A 386SX would benefit hugely from a Windows accelerator, because it can spend all its time on running the OS and applications, not on drawing the screen.
Ugh, you have L2 cache? That speeds this boy up quite a bit.
I remember my sx @ 20MHz without cache, and win95 wasn't really usable...
wrote:wrote:So 8MB 0-wait memory + 386sx16 + 256kB L2 cache + 4GB CF card = barely acceptable Windows 95 machine IMO
I'm sure it would, thing is this is the only retro machine I have that is "factory original"
I've added a SCSI, sound and network card, and replaced the failed ST-157 (F in the chat for that boi) with the CF card, but I really don't want to remove original components that still work.
I managed to install win95 with 3mb of ram on my 386sx25. Usable no. But 8mb should be fine. I was using win95 with 8mb oringally when purchasing my Pentium 100. yes Bit swapping but ok.
I agree with my presuccessor to go for an win accelerated GPU though
1) VLSI SCAMP 311 | 386SX25@30 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | SG NX Pro 16 | LAPC-I
GigAHerZ wrote on 2019-12-14, 20:50:Ugh, you have L2 cache? That speeds this boy up quite a bit.
L2 cache? The 386SX doesn't have internal cache, so if there's any external cache it's not L2. Not sure how much cache would really differ - the big bottleneck is the 16b bus.
maxtherabbit wrote on 2019-12-08, 22:53:so as long as I got OS/2 2.1 I can get win3.1 app compatibility and it should run ok? sounds like we may have a winner
Windows under OS/2 (WinOS2) will not work with VXD drivers for things like sound support for Windows applications .
Normal programs should run fine, I think.
I ran 2.11 on a Compaq Contura and noticed no issues.
16-Bit drivers with the *. DRV extension should also work.
VXDs, as used by some fax programs, may cause trouble.
That's because OS/2 uses the ring scheme more sophistically than 16-Bit Windows.
Anyway, the matter is quite extensive. 😅
Simply put, WIN-OS/2 is a special build of Windows 3.1 (IBM has Win 3.x source code).
It was adapted to run in the OS2VDM.
It is a DPMI client, for example, rather than a DPMI host.
OS/2 Warp also can run Win32s 1.25a or Odin to support Win32 programs.
maxtherabbit wrote on 2019-12-07, 14:56:which would run less shitty? win95 original or OS/2? I kind of hate windows 95 tbh so not sure how fun that would be
XENIX is looking like the beast option right now
If we’re going down that rabbit hole throw on an old copy of AIX, compile some goodies and run CADAM 3
dionb wrote on 2020-07-21, 21:49:GigAHerZ wrote on 2019-12-14, 20:50:Ugh, you have L2 cache? That speeds this boy up quite a bit.
there is no cache on that machine, I was smoking crack when I posted that apparently
If you're going 32-bit I'd probably use OS/2 2.x because it can also run DOS applications. Not sure about software support. I have 2 copies of OS/2 2.x (2.0 and 2.1 with Multimedia Support and Win OS/2) and I have run them on a few 386s including a 386SX with some pretty nice performance.
~The Creeping Network~
A busmaster SCSI controller is almost a must if you really try to run Windows 95 on a 386SX.
I'm running a 20 MHz 386SX and it was a huge difference switching from IDE to the Adaptec 1542B.
Disruptor wrote on 2020-07-23, 16:22:A busmaster SCSI controller is almost a must if you really try to run Windows 95 on a 386SX.
is this a difference that can be measured/documented?
what about network/video - is there some meaningful speedup possible?
i remember win95a was slow for me on a 100mhz cyrix with 8 megs with a relatively fast s3 pci card
i did not have network iirc but serial/parallel comms was a huge load too
you feel it
the CPU will do other tasks while the SCSI busmaster is transferring data from hdd to memory or vice versa
the CPU cannot do other tasks on an IDE system, because PIO (programmed I/O) means that the CPU is used to transfer data
Yes, there are better network cards than NE2000 compatible.
I know this thread is petering out, but just thought I'd mention that people definitely ran Linux on slower 386SX CPUs with just 4MB of RAM in the early to mid 90s. A very early version of Debian or Slackware should work well in 8MB, even with X. I believe very old version Debian mirrors are still live, but maybe you could track down a multi-CD version containing the whole repository. i understand that was fairly common in the dial-up era.
I'll admit this is veering into Stallman territory, but probably less so than running a vintage Unix like SCO. Much more documentation available, more intended for one person to administrate.
