First post, by kane198021
Hello all!
I'm on the hunt for compatible original software for this machine:
As far as I can tell this machine was produced in 1996-1997, just before Compaq bought DEC. I have found one possibility on Ebay, but I cannot justify spending $25.00 on it when there's no guarantee that it will work. In other pictures that I have seen, it's evident that someone decided to downgrade the OS to Windows 3.11/DOS. I don't have the machine here yet because it's getting shipped from Italy to me in the USA.
Reply 1 of 7, by jakethompson1
It probably shipped with Windows 95 OSR1 or OSR2.
Are you just looking for that or you're hoping for some kind of restore CD?
Reply 2 of 7, by leileilol
Good luck either way. General information on DEC's last ditch efforts of x86-based computer lines tend to be buried. Your best source for this info might have to be diving into PC Magazine's ads/articles about them (and not some general cherry-picked DEC Alpha or mainframe legacy nostalgia piece).
Reply 4 of 7, by kane198021
jakethompson1 wrote on 2020-10-22, 00:34:
That's exactly what I was hoping for. Specifically, a Windows 95 with USB support or Windows 98 restore CD from DEC.
Reply 5 of 7, by PC Hoarder Patrol
kane198021 wrote on 2020-10-22, 04:52:
There are still some support files and links on archive.org for the Venturis FX-2 5xxx, including a system startup disk and a USB driver. Only seems to officially support W95 OSR2 and for some things I suspect you'd still need their System Software CD.
https://web.archive.org/web/20001121061900/ht … ndex/epid51.htm
You might also find other stuff thru the Master Index
https://web.archive.org/web/20001117134900/ht … ex/epidmstr.htm
Reply 6 of 7, by kane198021
PC Hoarder Patrol wrote on 2020-10-22, 05:50:
There are still some support files and links on archive.org for the Venturis FX-2 5xxx, including a system startup disk and a US […]
Thank you for that! I couldn't get that far when I tried going there myself. The $25 CD that I mentioned at the top actually costs more than I remembered and it seems to be the correct one, but I'm still unsure. Link:
https://www.ebay.com/itm/digital-Venturis-FX- … BH/312604395059
Reply 7 of 7, by PC Hoarder Patrol
I'd wonder if it's the right disk, as I see old ads online for Venturis FX-2 System Software CD Version 1.4 so maybe there were family-specific versions
http://sup.xenya.si/sup/info/digital/MDS/jun9 … PC/B00WWGAB.PDF
You could message that seller to check, and if confirmed for the FX-2 series then make an offer!
