First post, by Grayshazzle
Hello everyone, how would I go about this exactly, I have a one storage device which is a CF Flash Adapter and a 16 GB Card for 6.22 of course. I am not putting a floppy drive in my system as I have no use for it when it comes to games and rather will run them off of my CF card. So as a result, I downloaded a CD installer version of DOS 6.22 here: https://archive.org/details/msdos622cdinstaller with mouse/keyboard support and all. So do I first just install with the shortcut prompt on the CD version of DOS? I will link a pic below. Then after when I also install the CD drivers do I have to set up certain commands to install Windows 98 SE? I heard that copying the files from the CD to the Drive and then running the setup file there is more efficient. Also how would I go about setting up a boot GUI when the OSs are installed, so when I boot it up I have a menu to go into 6.22 or just plain Windows 98 SE. Thanks. Also lastly I am not sure if this version of DOS 6.22 (CD Install Version) even requires a boot disc, I am pretty sure OEM versions do not but count me possibly wrong.
