jmarsh wrote on 2021-09-06, 23:57:
You can mount all the ISOs (different discs) with one imgmount command and then use ctrl-F4 to switch between them, no need to exit windows or use the command prompt to issue a new imgmount command.
Or just go the old school way and mount a virtual CD-ROM driver, like MagicISO! 😉
It may sound stupid at first, but it works and is sometimes more convenient
than using the internal method.
I've been using this unconventional method approx. since the mid-late 2000s.
Back then, I had many CDs backuped up in NRG format, incl. mixed-session ones with audio-tracks and mac file system tracks.
Using the virtual driver was simpler and cleaner than converting to bin/cue/ogg.
