Dos 6 conventional memory tricks
Reply 240 of 256, by GigAHerZ
Carrera wrote on 2021-03-17, 10:27:
I remember that tip as well!
Also, if you were lucky to have 2 hard drives setting those parameters to the other drive could sped things up a bit...
Woah, what's the logic in that? Something related to seek times?
Reply 241 of 256, by Carrera
Basically.. Yeah
In general if you could afford it you put the operating system on one hard drive and all other stuff on another as you tend to read from one and write to the other thus saving (admittedly milliseconds) time.
It was probably not very useful....
There was also a trick of doing this with the other functions. I am nut sure it was SmartDrive or the swap file maybe...?
Reply 242 of 256, by megatron-uk
Actually, splitting temporary file areas, swap and other things across multiple drives, as well as seperating the OS out from applications is still very common - think about a modern multi-tasking operating system; it's nearly always doing more than one thing at a time. In the days when hard drive transfer rates were measured in single digits to dozens of megabytes it was incredibly easy for one badly performing process to lock up your system by starving all IO.
Move the IO for that application to another drive/channel, and your other applications (and the OS itself) can continue with other IO requests while that application (slowly) performs its reads and writes.
https://www.target-earth.net
Reply 243 of 256, by Jo22
^^ I think the same.
I guess ROM-based operating systems like Atari TOS did have an advantage here.
They had instant access to their libraries of code, without needing fixed disk drives.
In fact, they still have that advantage.
They never had to fight over disk i/o with the applications.
Operating systems like Windows will always be behind in this specific point, I think,
unless they are being run on a RAM drive.
Speaking of RAM drives/disks, Linux has the ability to run in such an environment (TO RAM argument).
However, if we're a little bit sarcastic, we could say that it requires that option somewhat badly also.
It handles everything through the file system, after all (everything's a file). 😉
Reply 244 of 256, by GigAHerZ
Well, today's operating systems keep a lot in the ram and therefore kinda run from a "ram drive". It's not a new idea...
Reply 245 of 256, by Intel486dx33
By loading everything high in config files on my 486 I am able to use just 3 megabyte’s of conventional memory of my 16 megabyte’s of ram.
Has anyone been able to use less on a 486 running DOS 6.22 ?
Reply 246 of 256, by cyclone3d
Intel486dx33 wrote on 2021-06-03, 05:13:
What? Conventional memory is the first 640KB of RAM.
Did you mean to say that you are able to only use 3KB of conventional memory, giving you ~637KB of free conventional memory?
Yamaha YMF7x4 Guide
Reply 247 of 256, by Caluser2000
cyclone3d wrote on 2021-06-03, 05:25:
I'd like to see his config.sys and autoexec.bat files........
As well as the C:\>mem output.
Reply 248 of 256, by GigAHerZ
Caluser2000 wrote on 2021-06-03, 06:50:
"mem /c/a > output.txt" would be the best. 😀
Reply 249 of 256, by honx
BloodyCactus wrote on 2019-03-05, 20:01:
its in this zip
https://kråketær.com/stuff.zip
mcbexp for mcb expander. I dont know if its latest version, I'll check when I get home tonight.
this link doesn't seem to work anymore. 🙁
can you please reupload that zip file? thanks in advance!
Reply 250 of 256, by BloodyCactus
honx wrote on 2021-08-26, 19:32:
its in this zip
its in here
Releasing some of my old DOS stuff
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
Reply 251 of 256, by Nemo1985
I'm wasting back some time trying to further improve the free conventional memory.
I'm wondering in your opinion which of those 2 setup is better:
Older configuration:
 Tipo di memoria      Totale         Usata     Disponibile
Convenzionale 655.360 14.704 640.656
Superiore 223.664 57.824 165.840
Riservata 393.216 393.216 0
Estesa (XMS) 132.945.488 10.929.744 122.015.744
Memoria totale 134.217.728 11.395.488 122.822.240
Tot. inf. a 1 MB 879.024 72.528 806.496
Dim. massima di un programma eseguibile 640.640 (626K)
Dim. massima di un blocco libero di memoria superiore 155.248 (152K)
New configuration:
Convenzionale 655.360 9.968 645.392
Superiore 196.144 57.824 138.320
Estesa (XMS) 132.973.008 10.854.864 122.118.144
Memoria totale 134.217.728 11.315.872 122.901.856
Tot. inf. a 1 MB 851.504 67.792 783.712
Dim. massima di un programma eseguibile 645.376 (630K)
Dim. massima di un blocco libero di memoria superiore 122.496 (120K)
The new configuration gives 4kb of free conventional memory but the upper memory block is quite smaller (that's a general configuration it still needs audio driver to be loaded and probably something else), also 626kb of free conventional memory should be enough for any program, is that right?
Reply 252 of 256, by Caluser2000
GigAHerZ wrote on 2021-06-03, 08:21:
Have we seen this yet?
Reply 253 of 256, by Caluser2000
Nemo1985 wrote on 2021-09-01, 03:21:
I'm wasting back some time trying to further improve the free conventional memory. I'm wondering in your opinion which of those […]
New configuration:
In the big scheme of things it isn't going to make much difference at all.
Reply 254 of 256, by Nemo1985
Caluser2000 wrote on 2021-09-01, 04:10:
Well the first configuration use xmgr.sys and emm386, while the second use jemmex (I wasn't able to use xmgr and jemmex).
That being said, can you please elaborate? Which one would you use?
Edit: I just noticed that with jemmex windows 3.11 doesn't run because it complains the lack of himem.sys
Reply 255 of 256, by canthearu
Carrera wrote on 2021-03-17, 11:05:
Basically.. Yeah In general if you could afford it you put the operating system on one hard drive and all other stuff on another […]
Basically.. Yeah
Wouldn't make any difference in DOS though.
DOS is strictly single tasking. It will sit there waiting for each I/O to complete no matter which drive you send it to.
Maybe with SMARTDRV or other smart caching software, you could eek out a small measure of improved performance with multiple drives vs 1, but it wouldn't be much.
To get benefit from multiple drives, you need software that is able to do multiple things at once.
Reply 256 of 256, by canthearu
In terms of how much I try to optimise memory, I don't run a lot of drivers on most of my systems so it isn't really that hard.
Default HIMEM.SYS then EMM386.EXE. Load DOS and all the drivers high. Do mild optimisation to get conventional memory free, and whatever high memory is left is fine, as non-TSR software generally doesn't care about high memory.
