First post, by CapnCrunch53
- Member
Hey guys, been messing around with my Pentium system the last couple nights and I'm having this problem with X-Wing. This is the DOS version of the Collector's CD-ROM. Another possibly important note, I'm actually using Windows 95 OSR2 in DOS-only mode. The AWE64 drivers are (to the best of my knowledge) setup correctly.
Problem is real simple: I load the game up, the intro plays fine, AWE Midi sounds fine, and then I get to the screen where I can enter a name. When I click "Enter Spaceport" the game just hangs. Mouse stops responding, can't do anything on screen, can't reboot with CTRL-ALT-DELETE. The system isn't totally frozen though; the num/caps/scroll lock keys on the keyboard respond, and the music keeps playing.
Any ideas? I'm using EMM386 for EMS memory, which I've very noob at and basically just copied what I found online. Could that be the problem?
Configuration:
Pentium 200MMX
Asus TX97-XV (an OEM HP version of the board that doesn't have very many BIOS settings)
4x16MB 60ns EDO memory (I should point out that even though both pairs say EDO, when all four are in, sometimes BIOS reports the second bank as FPM, but sometimes as EDO. I've taken out those two sticks and the problem persists)
Matrox Mystique 220 4MB
Diamond Monster 3D 4MB
Creative Sound Blaster AWE64 CT4380
7GB Quantum Fireball
Generic floppy and DVD-ROM (because it was spare and beige) drives
Windows 95 OSR2 booting into DOS-only mode
I'll type out my autoexec.bat and config.sys files here in just a few; while I do though if anybody has seen this problem and already knows off the top of their head what it is then super.
Thanks!
Edit: should probably point out the game disc looks fine to me, though that doesn't necessarily mean anything.
Edit 2: I just realized there's supposed to be speech and sound effects in the intro. Yeah... I'm not hearing any of that, only music. So that's probably bad. In the INSTALL.EXE setup program it plays AWE32 music and digitized sound effects just fine though.
PCs, Macs, old and new... too much stuff.
