First post, by DOSfan1994
Hello, Happy new year!
I have a problem regarding about install Windows 3.1 on FreeDOS, I am installing windows 3.1 from my floppy disks I ran into a message saying "Windows cannot run in standard mode, please install or load your HIMEM file."
If you have a way to fix this please leave a post.
Reply 1 of 42, by Dmetsys
HIMEM.SYS is not part of FreeDOS, it's only part of MS-DOS. You can use HIMEMX, HIMEM.EXE or FD-HIMEM, but FD-HIMEM was known to be buggy. Frankly, I'd use a real copy of MS-DOS with Windows 3.1.
If you wanted to try HIMEM.EXE, you can put the following into FDCONFIG.SYS;
DOS=HIGH,UMB
DEVICE=HIMEM.EXE
That should enable FreeDOS to run in extended memory mode.
NF7-S 2.0 | 2500+ @ 3200+ | 9700 Pro | Audigy2 ZS
CUV4X 1.03 | PIII-933 | MX400 | Live! Value 4670
P5A-B | K6-2 450 | TNT2 | AWE64 Value
4DPS | Am5x86-P75 | S3 Vision864 | SB16 CT2290
Reply 2 of 42, by Ampera
I agree with Dmetsys. Modern DOS clones can be neat, but there is no beating a legacy DOS version. I use PC-DOS 2000 myself, but you could use MS-DOS 6.22, PC-DOS 7.1 for FAT32 support, and if you really want to, Dos 7.1 is available from the China DOS union.
Memory management in DOS is definitely a clustertruck and drivers aren't any prettier, but that's what you get for an OS based on CP/M from the early-mid 70's.
There is also OS/2 which is like DOS and Win16 on cocaine infused steroids. It can be tricky to find a legit copy, but that never stopped anybody before.
Reply 3 of 42, by DOSfan1994
You can't use MS-DOS 6.22 for FAT32 8gig partitions.
Reply 4 of 42, by Ampera
PC-DOS 7.1 is your friend then!
But FAT32 and DOS is pointless. If you want FAT32 and DOS, then your system is powerful enough to run Windows 95 B or OS/2 Warp.
DOS doesn't NEED more than 2GB of space, and unless your loading 20 DOOM installs (I raise my hand) you don't need much more than 500 MB most of the time.
But that's not what has stopped anybody
PC-DOS 7.1 has the IBM coolness factor (Who doesn't like IBM, it's like your grandfather or uncle, they try their very best, but everybody ends up stealing their work) and
MS-DOS 7.1 from the China DOS union is definitely an option.
You could also install 95B, and strip all the UI elements out until your left with MS-DOS 7.1, but my advice for that is to probably try and use the sys command if that exists in 95B to copy onto a floppy, move utilities like FDISK onboard, and then go back and do the reverse.
FreeDOS is an option, but it has the disappointment of being not retro. Personally I take qualm with this, I prefer period accuracy vs. modern convenience, so I'd rather swap 12 floppies instead of getting a USB floppy emulator and sit there clicking buttons. It might be useful, it might be fast, and it might save your hair when and if normal floppies would go wrong, but we are here for the retro experience.
My opinions aside, DR-DOS is also something you could try, but I am not sure if it has FAT32 support.
Reply 5 of 42, by gdjacobs
DR-DOS does have FAT32 support in it's OpenDOS incarnation. You'll want OpenDOS 7.01 and then patch it to WIP (WIP adds FAT32, so start with a smaller boot/OS partition then add big ones once you're patched).
Reply 6 of 42, by Jorpho
Its origins are a complete mystery. I sure wouldn't consider it an option.
The Chinese DOS 7.1 should be even less desirable in that regard.
I agree that DR-DOS is worth considering, though I keep losing track of the various forks and legal problems. And yes, it has drfat32.sys. (In theory, you can use that with other versions of DOS, too.)
I also agree that you shouldn't need more than 2 GB for most DOS purposes and in fact you may encounter compatibility problems if you have that much free space.
Reply 7 of 42, by Ampera
Jorpho wrote:
Its origins are a complete mystery. I sure wouldn't consider it an option. […]
Yea it is a complete mystery. Like a lot of stuff in the retro computing world. Try to find good amounts of info on DataExpert or Data Technologies Corp. The best I got was DTC's old headquarters in California, yet I still use both their parts. The DOS 7.1 option I agree is not as good a PC-DOS 2000, which is what I use, but I would take it over FreeDOS.
I would also take MS-DOS 6.22 over FreeDOS because of the principle of my builds. The newest parts are either old design new make, or because I don't have anything older.
Reply 8 of 42, by Dmetsys
I don't think I have seen a DOS/Windows 3.1 machine that had a hard drive with over 500MB in storage capacity, mostly due to BIOS C/H/S limitations. I'm a purist myself, and would only use MS-DOS if I wanted a proper Windows 3.1 build.
Reply 9 of 42, by xjas
You can run win 3.1 on FreeDOS fine. There are ways to do it with the native JEMM386/HIMEMX, but it's easier to just copy over EMM386/HIMEM.SYS from MS-DOS and get the best of both worlds.
Reply 10 of 42, by DOSfan1994
But what about turning of the 386 enhanced support?
Reply 11 of 42, by gdjacobs
I wouldn't use the included memory management TSRs for that reason.
Reply 12 of 42, by Ampera
Your porking at one.
Lol, I have a 486 DX4-100 build with 2GB drives fully usable by DOS
Reply 13 of 42, by DOSfan1994
What version of DOS should I use if I don't want the included memory management if I want to use Windows 3.1 on FAT 32?
Reply 14 of 42, by Dmetsys
The DX4-100 was certified to run Windows 95. 😜 I wouldn't classify a DX4-100 to be a DOS/Windows 3.1 era processor, but to each their own I suppose, haha. 🤣
Reply 15 of 42, by Ampera
You can run Windows 95 on a 386, yet I can't even max out Duke Nukem on a DX4-100.
Reply 16 of 42, by Dmetsys
You can BARELY run Windows 95 on a 386DX, even though it's listed as the minimum requirement for doing so.
Reply 17 of 42, by Ampera
The DX4-100 is a perfectly fine DOS chip. Even some of the P5 chips were still good for DOS. You CAN run Windows 95 on a DX4-100, and I do run it, but I also run PC-DOS 2000.
Reply 18 of 42, by Jorpho
This sentence does not make grammatical sense.
If this is about Re: A problem when trying to install a Living books game on Windows 3.1 on PCem. again, then your problem arose because you were trying to run Windows with an unholy amount of RAM and not because it was in 386 enhanced mode. If you want to be certain about avoiding strange compatibility issues, then there is no substitute for MS-DOS 6.22.
And you shouldn't use Windows 3.1 on a FAT32 drive. Period.
Reply 19 of 42, by Ampera
Jorpho wrote:
This sentence does not make grammatical sense. […]
There ARE substitutes with perfect compatibility. PC-DOS is your best alternative as it has more and better features than MS-DOS, and it has the cool IBM aspect to it (Who doesn't love IBM). It's based on the same codebase, and until version 6, was developed together with MS-DOS.
But Windows 3.1 cannot access more than 2GB anyways, you will only encounter issues with drives over 2GB, and there is no real reason to use drives over 2GB. As I said, Windows 95b/c is when you want larger drives. You get DOS support, and a better version of Windows.
I sympathize, until a while, my smallest drive was 20GB IDE, but you still need to keep it to 2GB.
