First post, by .legaCy
Hardware:
ASUS P5P800-VM
Intel Pentium 4 3.0
ATI Radeon 9600 Pro
512MB DDR400
Running on Windows 98 SE.
In software mode it runs great, but it freezes on the race start(it render a few frames and freeze).
Ahh just to add, i'm using USB keyboard/trackpad and USB Joypad, but i don't think that this is the issue because it works well on software mode.
Useful links
[ How to Multiboot any OS | Rebuilding GOG Installer for Win9x | 486DX-4 Build | S7 Time machine Build |
twitch stream (in portuguese)
Reply 2 of 8, by derSammler
notsofossil wrote:
Do you have kernel ex installed and have it active for NFS3?
I don't see any connection between this and the error he has with the game. NFS3 is a 1998 game, so kernelEx is completely pointless.
Anyway, on such powerful hardware, I'd recommend to just use the NFS3 modern patch. It will most likely fix your issue.
Reply 3 of 8, by the_ultra_code
Hello.
.legaCy wrote:
512GB DDR400
I hope you mean megabytes? Right? 😀
Besides that, as derSammler said, try the modern patch version of NFS3 (found here: http://veg.by/en/projects/nfs3/). When I found out about it, I installed it on my Pentium 3 system and was able to transfer my game data from my CD installation of the game to the modern patch, and actually, from what my eyes could tell, I could see a small performance increase, not to mention all of the little improvements that the developer made in-game.
However, if you wish to continue to play the vanilla version of the game, maybe you'll find a useful patch/file or two here on EA's own servers for the game (ftp://ftp.ea.com/pub/ea/patches/nfs3/).
Here's my question, though: What API are you trying to use in hardware mode? DirectX or Glide through something like nglide or dgvoodoo?
Builds
Other:
* USB2 PCI Card in Win98 SE
* Futuremark Result Browsers
Reply 4 of 8, by .legaCy
the_ultra_code wrote:
Hello. […]
Hello.
.legaCy wrote:
512GB DDR400
my bad, it is MB, i will try this patch
I'm trying to run on DirectX.
Useful links
Reply 6 of 8, by .legaCy
Hmmm.... Another question: what version of DirectX are you using?
Well i need to check that, but others Direct3D games works fine.
Useful links
Reply 7 of 8, by the_ultra_code
Just open "Run" and type "dxdiag.exe". That'll bring up a window that will tell you what version of DirectX you are running. You can even do it in Windows 10. It's really easy, I promise. 😀
Builds
Other:
Reply 8 of 8, by the_ultra_code
So, .legacy, any updates? Have you gotten around to checking the DirectX version you are using under Win98?
Builds
Other:
