First post, by rickee000
Trying to get this off the wall classic to run and despite install and setup running OK - I get an error message saying there is not enough conventional lower memory.
It needs 570K and looking at 'mem' - I've got 488K free out of 640K (so using 152K).
Mem is saying I've got 0K Upper, 0K reserved, 66,122K Extended (XMS).
Blood's setup utility recognises the Extended Memory but insists I have that minimum 570K conventional. I've tried adding 'NOEMS' and 'RAM' to the end of the EMS line in Autoexec.bat with no luck.
I'm guessing the solution is to try and free up that 152K but my Autoexec and Config files are pretty lean - with everything I can loaded into higher memory.
Any ideas on how to get or free up more conventional memory or otherwise get round this issue?
Cheers
AUTOEXEC.BAT:
ECHO@OFF
C:\WINDOWS\COMMAND\MSCDEX.EXE /D:MSCD001
SET BLASTER=A220 I7 D1 H5 P330 T6
SET CTSYN=C:\WINDOWS
C:\PROGRA~1\CREATIVE\SBLIVE\DOSDRV\SBEINIT.COM
LH C:\MOUSE\MOUSE
CONFIG.SYS:
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICE=C:\WINDOWS\EMM386.EXE
DOS=HIGH,UMB
LASTDRIVE=F
DEVICEHIGH=C:\WINDOWS\COMMAND\OAKCDROM.SYS /D:MSCD001
