First post, by Caluser2000
- l33t
The title is petty explanatory. Show off your emulators used on your non x86 platforms pre 2000. Includes software and any hardwar,e including those with x86 cpus on them.
As some know I've recently resurrected an Acorn A3000 from 1989 which has been upgraded to 2megs of ram and RicOS 3.11 in ROM. Somewhere along the line I'd acquired some Acorn PC emulation software. One does single user mode which takes over the entire screen like an normal early x86 system. The other runs under the multi-tasking environment of RiscOS 3.11. the version of MS Dos that came which the emulators I have is version 3.3 which was released in 1987 and was a very popular version of Dos. So much so DRDos 5 and 6 reported that version when programs queried them. A varient of MSDos 3.3 was created by Compaq to address the 32meg HDD limit issue called Compaq MSDos 3.31.
Lets see what you guys and girls have used or are playing with now or in the past. Post some picks if you have any and above all have fun.
