First post, by SpectreVR
After fighting with all sorts of partition resize tools and re-imaging my Win98 install (I was smart and made backups using Win32DiskImager) I finally found a way to resize the partition without any corruption!
I used an old version of gparted and it just worked! No need for "fdisk /mbr" or "sys c:"! I just rebooted and there it was! I also did a ScanDisk to verify it was all working and it seems to be good.
gparted-livecd-0.3.4-11 from https://sourceforge.net/projects/gparted/file … gparted-livecd/
Reply 1 of 7, by clueless1
I went through that journey too awhile back. Likewise, you need an old version of Clonezilla to image a Win9x drive and successfully restore it. I can't remember the version off the top of my head, but if you search my posts, you should come across it.
Reply 2 of 7, by Caluser2000
On smaller drives I use Partition Magic. Good for changing partition types like fat16 to hpfs, fat16 to ntfs and more. Seems period correct and "retro" for some strange reason.
Reply 3 of 7, by MrSmiley381
Rad. I've run into issues like this before so having a reference version for a case like this is always helpful. Does this version still requires a CPU with a Pentium Pro or better instruction set? I've tried to use GParted on a Pentium MMX before and needless to say I was a tiny bit heartbroken.
On a related note, is there any way to have an unformatted chunk of hard drive space on a 98SE machine and not have it panic when it runs ScanDisk? If I have have a 96 gigabyte partition and a chunk of hard drive space unformatted, the error message is just something about an unreadable partition. I doubt it hurts very much but it's still annoying.
I spend my days fighting with clunky software so I can afford to spend my evenings fighting with clunky hardware.
Reply 4 of 7, by Jo22
Good to hear it worked. Reminds of an old link about GParted 0.9x..
https://forums.opensuse.org/showthread.php/46 … FAT16-and-FAt32
Reply 5 of 7, by andreszs
Caluser2000 wrote on 2019-10-14, 19:43:
Unfortunately it does not work when it comes to resizing partitions. The Powerquest Norton Partition Magic 8 shows all the steps to resize the partition, and then it kindly asks to restart in MS-DOS mode to perform the resizing. However, upon restarting, I simply get a message about continuing in MS-DOS mode or returning to Windows. No resize is ever performed. Any ideas why? It seems strange that Norton purchased this software just to neglect and abandon it forever.
This is Windows 98 SE, I simply changed the colors and fonts to resemble Windows 2000 because I can.
Reply 6 of 7, by stanwebber
i think gparted prior to v0.8 is safe for resizing fat32 non-destructively (parted library crippled fat support subsequent). 0.8.x versions may work as well, but for sure earlier. don't forget to enable the lba flag for fat32 partitions on large drives or scandisk will complain.
Reply 7 of 7, by Warlord
andreszs wrote on 2023-03-30, 21:17:
Unfortunately it does not work when it comes to resizing partitions. The Powerquest Norton Partition Magic 8 shows all the steps […]
you should of just luanched pqmagic from pure dos by typing the exe or from a boot disk like normal. make sure to load a mouse driver although its not needed.
