First post, by Eirle
- Newbie
Hi guys, I see that some people have problems trying to run TES Redguard in 3Dfx mode, I wanna run it in 3dfx using dgvoodoo 1.40+ in my old Toshiba Dynabook,a AMD K6-2 300mhz,with a S3 Virge MX 260 GPU,64mb ram,that in xngine mode is playable,well,I run dgvoodoo server application because Windows Me don't have connection between DOS and Windows as said in the readme.
I run RGFX.exe and I can see that it start, black screen appears, then it changes resolution and goes back to standard resolution and dgvoodoo and rgfx close, I've been trying to run in 3dfx mode a couple of weeks, I just wanna play it with the dgvoodoo in my pure Windows without DOSBox and VMware emulation.
I put dgvoodoo in Redguard directory, I don't know if texture cache in dgvoodoo setup is the use of my RAM.
I see a window open named gdvoodoo glide 2.43 (640x480), it stays black and then closes.
Why has God abandoned us?
