First post, by adama
Hey guys, not a problem per se, but more looking for an explanation of an issue i was having that seems to have resolved itself.
I got an EP-MVP3G2 earlier today, and fitted it with an AMD K6-3 that I rescued from an old Cobalt RAQ4i. After eventually finding RAM it liked, I tried to install Win98.
I found an old drive, wiped the partitions, created a FAT partition, formatted it, installed, at first boot it just sits at the end of the BIOS output, doing nothing. Same with a second drive. Now, I think these had both been running either FreeBSD or Win2k previously, so "an" issue is obvious...
After a while of reinstalling, lightning struck, and I booted with the win98 boot cd and ran "fdisk /mbr". But it didn't work! It just stopped at the end, right where you'd expect the loading message to appear.
So as a final try, I burned a FreeDOS 1.2 CD, and installed that (running FreeDOS's fdisk /mbr at the end of the install). FreeDOS booted!
So I booted the Win98SE CD again, formatted C: and reinstalled. It booted!
Why? Is the FreeDOS fdisk doing something the Win98SE fdisk didn't?
It's been a good 15 or so years since I installed Win98SE, so I had forgotten about the tricks like using fdisk /mbr (and using a linux distro to create a quick FAT32 filesystem!), but certainly back then I never had freedos, so I'm not sure what I'm missing.
